Remedial Finishing
Forum topic by Odiferous posted 03-14-2013 05:58 PM 815 views 0 times favorited 2 replies Add to Favorites Watch
View Odiferous's profile
Odiferous
105 posts in 2432 days
03-14-2013 05:58 PM
Topic tags/keywords: novice
I see articles and videos galore about choosing finishes and techniques for applying finish, but very little about the finishing process in general. I knocked out a quick little project in a few hours, and decided to try a wiping varnish finish on it, and I’m struggling to figure out how this is going to work with larger projects.
  • “They” say to apply the finish and leave the room so you don’t stir up dust. For 6-10 hours. Maybe longer (I’m down by the gulf coast—humidity central). For 4 coats. Oh, and I want both sides finished. So the workshop is out of commission for 4 days to finish a 4 hour project?
  • “They” say to use pieces of an old t-shirt to apply finish, then lay it flat to dry. Again, 4 coats, both sides. Oh, and use 2-3 pieces to make a thick pad so your fingers don’t leave streaks. How many t-shirts do these people wear? Do I really need to buy a bag of rags and a box of gloves for every other project?
  • For my last finish project, I assembled it before finishing. This left me with pooled finish in the inside corners. This time, I masked off the joints and started finishing first. This left me with finish built up at the edges of the tape, and dry spots where the tape wasn’t cut perfectly to the edge. Which approach should I be defaulting to?
  • How do I “flood the finish on” without getting runs to the underside? It’s not like I’m pouring a ton of finish all over the place, I’m just being generous with the rag—I know the red oak I’m using is going to soak up a bit. This doesn’t seem to change whether I’m doing my usual “finish the top and lay it on cardboard” or finding something to use as makeshift painter’s pyramids.
This is a skill I want to learn, so I’m making myself finish things even when I don’t think it’s necessary, but if anyone has some suggestions, I’d appreciate it.
2 replies so far
5242 posts in 2734 days
#1 posted 03-14-2013 06:12 PM
I’m afraid the only way to avoid dust may be that effort of leaving the shop out of commission, or use something that dries faster. As for the T shirts, you can buy them at second hand stores…or you can use those blue paper shop towels that any auto store or Walmart stocks. These blue ones (called Shop Towels) are lint free and are great for wiping varnish, use and toss. It does pay to wear those disposal nitrile gloves. I typically finish after assembly, though there are arguments for both ways. I wouldn’t “default” to either, but pick the one that would seem to work best for a particular project. Some of them would be almost impossible to finish after assembly, and visa versa. I don’t flood any finish on, though I will do that with dyes. Especially on red oak, it will expel some of that at a later point. It common to recommend a book, and i will: Bob Flexner's book excellent and easy to read. There is another one by Jeff Jewitt has pretty much the same info, but is organized a little different. One or both should be required for any hobby shop.
View Clint Searl's profile
Clint Searl
1533 posts in 2602 days
#2 posted 03-15-2013 12:01 AM
There’s a lot of silliness in the finishing business, beginning with the myth that “flooding” will increase penetration. WRONG! no finish will penetrate more than a few wood cells deep, and as the first coat cures, it creates a barrier to further penetration by subsequent coats. What this means is that the first coat can/should be applied only enough to achieve full coverage, and wiped off after a few minutes. Following coats will simply integrate with it and build up the resulting film.
