Jebus. So I finished my first “ambitious” project, an astronomy eyepiece case. I based the design off a commercial wooden case, and since they use Helmsman Spar Urethane to finish their cases, I followed their lead and used it on mine.
While I’m certainly not a fan of the stuff now (hindsight being 20/20), I’m now somewhat married to it since the inside and outside was finished with it, and there’s no getting it off. The last coat was applied Saturday, and on Sunday I moved the case outside to air out (we’ve been getting unseasonably warm weather of late, so it’s been clear with temps in the mid 60s/low 70s all week) and moving it back inside at sundown. Five days of that, though, and the finish still absolutely reeks.
Since this case will hold pushing $1,000 worth of sensitive coated optics, it’s unusable as long as this is going on. So anyone got any advice to speed up the destankification process? Is this something that needs patience, or am I potentially screwed?
-- Gaz. Irishman who lives in the San Francisco area, and tends to ruin more wood than he should.
It may take a month or so to cure, but it will. Spar varnish cures by oxidation, not by drying, so make sure air circulates. Cabinets finished inside with varnishes can take months to cure inside if there is a closed door inhibiting air flow.
I would be willing to bet the inside of that case is going to smell for a really long time. Like Loren said, it takes reacting with the air….if that will be unacceptable, I’d say you may be potentially screwed. When ever you finish an interior surface and you don’t want an odor problem, try using shellac, lacquer, or a waterborne finish.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
Crap on a cracker, that’s what I was suspecting. But yeah, since I lined the bottom and lid of the case with velvet, I can’t just strip it off and refinish. Looks like this thing is going to be staying outside for a few more weeks…
Maybe you could find some of that “stuff” that absorbs odors … Kinda like the stuff that sucks up moisture. If you could buy that stuff in say a quart or 1/2 gallon size you might could close it up in the case and let it do it’s thing?
Yep, looks like that’s the only option. It’s downstairs with a fan blowing on it, and a dehumidifier in the room (not that this will do any good for oil, it’s just there in general), and hopefully it’ll get sorted.
The stenkee hum will go sooner rather than later open it up to the elements and let the air circulate and it will be a good stout strong finish in the end.Alistair
Yarrr, it no be exposed to the harsh elements, mateys. But yep, hindsight being what it is, I’ll never use this #$# again. Two weeks now, with one week of it opened up completely in front of a fan running 24/7, and opening the case if it’s been closed for 15 minutes smells like opening a fresh can o’ urethane. Staaaaaanky.
I have a small curing oven heated by light bulbs. It holds one guitar body or about three small projects. It has an air flow passive vent system and with about two days with the oven at the usual 92’ temp, urethane stank goes away. For you, maybe direct sunlight with a small fan?
8790
220
28
61
78
1530
3547
15767
2034
495
2837
808
901
766
2740
1547
6156
