2 Questions for Experienced Dye Users
Forum topic by Lee Barker posted 68 days ago 248 views 0 times favorited 4 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
1887 posts in 1019 days
68 days ago
The project: Embellishing a dilapidated oak library chair, specifically the seat. It is glued up, probably white oak.
The dye: Lockwood’s ebony, water.
The question: How long do I wait before either spray (rattle can) lacquer or poly? Function is not the issue, time is. I am free to use either.
And, in general, have you ever wetsanded with dye? Just curious on this one.
Thanks kindly,
826 posts in 662 days
#1 posted 68 days ago
All you are waiting for is the water to evaporate, at that point it’s dry. So you can usually start yor top cpats fairly quickly. I usually put on one or two coats of the topcoat and then sand the “whiskers” (from the raised grain). This allows the finish to lock them in, and one sanding and your done with the raised grain problem. I’ve never wet sanded with dye, can’t think of a reason I would do so…not to say there isn’t one, it’s just one I haven’t encountered.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Clint Searl's profile
Clint Searl
848 posts in 530 days
#2 posted 67 days ago
Because I pre-wet with plain water before staining, I usually wait overnight to allow for complete drying. Then rub down with maroon scotchbrite before the first coat of lacquer, followed by another rub down if there’s any grain raised. Then it’s a s many coats as necessary to get the build I’m happy with, completing with a rubbing out with 0000 steel wool lubed with Butcher’s or Johnson paste wax, and a rag polishing.
-- Clint Searl.............We deserve what we tolerate
Lee Barker
#3 posted 67 days ago
Thanks for the help. You can see the results of the dyed chair seat here.
I put a fan on the piece to dry it and started the lacquer about 30 minutes after dyeing. Worked beautifully. 4 coats of lacquer and it was done.
Kindly,
Clint, you said “staining” and I wonder if you mean dyeing as well as staining?
Clint Searl
#4 posted 67 days ago
Lee, I was referring to water soluble dye stain.
