Home made bandsaw blade jig.
Forum topic by PatrickB posted 03-14-2013 04:11 PM 2218 views 0 times favorited 7 replies Add to Favorites Watch
View PatrickB's profile
PatrickB
53 posts in 3121 days
03-14-2013 04:11 PM
I b
uilt this out of some 1”x4” steel in order fix broken and make new bandsaw blades. It’s pretty easy to build, I just cut an equal distance down both sides, then drill and tap for a bolt. The pictures are pretty self explanatory.
Pat
-- Really? Really? How important is it?
7 replies so far
View sprucegum's profile
sprucegum
324 posts in 2171 days
#1 posted 03-14-2013 06:46 PM
Great idea what do you weld the blades with?
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Loren's profile
10477 posts in 3821 days
#2 posted 03-14-2013 06:56 PM
Is that an INCA?
View Surfside's profile
Surfside
3389 posts in 2347 days
#3 posted 03-14-2013 08:59 PM
That’s great work! Any techniques or more information about your band blade jig?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
#4 posted 03-14-2013 11:19 PM
I use the method described here:
http://wiki.vintagemachinery.org/BandsawBladeSoldering.ashx
My jig is a lot like the one in the article. I bought it many years
ago to repair narrow blades but I’ve recently acquired some
coil stock and started brazing my own. It’s easy but you do
need a jig to hold the band in alignment so it doesn’t braze
with a kink front to back.
PatrickB
#5 posted 03-14-2013 11:27 PM
sprucegun,
I use silver solder
YES!! After all these years I own an Inca 710 moooohhhaaaaaaa (evil laughter)
Surfside,
The two posts are very close together, about 1/2” apart to help prevent misalignment. Grind a long bevel on the opposite side of each end and join them together after a light coat of solder paste and then heat and solder. unfortunatly with silver solder you have to get it pretty hot so it has to air cool to not mess with the blade temper.
PatrickB
#6 posted 03-14-2013 11:34 PM
Loren,
That’s a nice jig for grinding the blade chamfer. Also, I suppose he hammers the silver solder flat to fit it in between the two pieces of blade. That’s another great idea there.
#7 posted 03-15-2013 12:02 AM
I have a 710 as well. Nice saw.
