Removal of dried Weldbond II
« back to Joinery forum
Forum topic by madts posted 03-14-2013 03:47 PM 1202 views 0 times favorited 1 reply Add to Favorites Watch
View madts's profile
madts
1841 posts in 2243 days
03-14-2013 03:47 PM
Topic tags/keywords: trick
We had some warranty done on our engineered wood floor. This floor already has finish on it and there is some glue squeeze out showing at the glue joints. Weldbond II was used. We have tried Googon without any luck.
Does anybody have any ideas, apart from refinishing the floor.
-- Thor and Odin are still the greatest of Gods.
1 reply so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2435 days
#1 posted 03-15-2013 01:16 AM
If the glue hasn’t bonded into the finish, you might be able to get it off using a hand plane iron laid flat on the floor and flush-planing it.
Try it on a small bit first. If you’re lucky, the glue will just pop off. If the glue has bonded into the finish, it will want to pull up the finish, and you are probably looking at refinishing.
-- Mark Kornell, Kornell Wood Design
