move TS cab. in one piece or do it in pieces?
Forum topic by Mainiac Matt posted 03-13-2013 04:04 PM 902 views 0 times favorited 9 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
7673 posts in 2237 days
03-13-2013 04:04 PM
Topic tags/keywords: move cabinet table saw
I’m rehabbing an old Jet 3HP cabinet saw and need to get it from my barn to the basement.
I’ve already taken the top, ext. wings and motor down, and now I have to move the cabinet.
Option 1. take the trunnion brakets off and attempt to unbolt the trunnion brackets from the cabinet and then move the trunnion assembly by hand as one piece (I”m comfortable with ~100 lbs.) And then man handle the empty cab down the steps into the basement. The problem here, is I’ve never had this type of mechanism appart b4 and I’m not sure if it stays together of if the trunnions fall out of the ways in the trunnion brackets as soon as they’re free.
Option 2. use my tractor bucket and chains to rig the cabinet (with the trunnions still in it) down the bulkhead and then man handle it onto a movers dolly for the ride to the other side.
Any one had their cabinet saw appart to move it?
Any advise is appreciated.
-- Pine is fine, but Oak's no joke!
9 replies so far
View hairy's profile
hairy
2608 posts in 3440 days
#1 posted 03-13-2013 04:43 PM
I’d go with option 2, leaving the trunnions as is. Maybe get a helper?
I moved two 14” bandsaws to the basement by myself. Taken apart as much as possible, re-assembled downstairs.
-- My reality check bounced...
View MrRon's profile
MrRon
4634 posts in 3152 days
#2 posted 03-13-2013 04:48 PM
I have the same saw. I would not go any further dismantling it. If the saw is properly aligned now, don’t mess with it. It will be a headache to try getting it all realigned again. While you have the top off, back off the tilt adjusting screw a bit more. This is an area where sawdust gets trapped and keeps you from returning the top to zero degrees; very hard to adjust when fully assembled. This is a good time to inspect the belts and replace if needed.
Shawn Masterson
1324 posts in 1857 days
#3 posted 03-13-2013 04:53 PM
Call a safe company some have machine that can carry it for you
View Loren's profile
9974 posts in 3556 days
#4 posted 03-13-2013 05:12 PM
A cabinet saw in that state of disassembly is likely
under 200 lbs and not even that awkward compared
to, say, a water heater full of sediment. Personally
I would just bump it down the stairs on a hand truck.
View helluvawreck's profile
helluvawreck
30161 posts in 2775 days
#5 posted 03-13-2013 05:20 PM
Strap it to a hand truck and go with it. It would help to have a helper on the downward end as your going down the steps. Strapping it to the truck is really worth the time.
helluvawreck aka Charles
Mainiac Matt
#6 posted 03-13-2013 05:26 PM
get a helper
Some how, every one I can think of to ask for help, already has back issues.
Mainiac Matt
#7 posted 03-13-2013 05:50 PM
O.K.
I just got permission to borrow a hand truck from work….
Plan is to strap the cab to the hand truck and pick up the whole affair with the tractor forks….. then carefully drive it over to the bulk head and rest the tips of the forks on the ledge and go for it down the steps with the hand truck.
Wish me luck.
Mainiac Matt
#8 posted 03-14-2013 01:12 AM
Mission accomplished…. and I didn’t even hurt myself
Mainiac Matt
#9 posted 03-14-2013 02:04 AM
thanks for all the replies…. follow along on my rehab blog if you care to see more
