mdf panels for frame and panel doors
Forum topic by Pabs posted 03-13-2013 01:36 PM 1438 views 0 times favorited 5 replies Add to Favorites Watch
View Pabs's profile
Pabs
230 posts in 3356 days
03-13-2013 01:36 PM
my next phase in my kitchen project is to give my existing doors a makeover.. They are made of solid oak… I will be using this oak to make a frame and panel style door.
So the rails and stiles will be from solid oak and then I will insert either glass or a panel in them.
It was recommended to me to use 1/4” mdf for the panels as they take paint very well and do no move like wood does
Is this pretty common practice?
-- Pabs
5 replies so far
View verdesardog's profile
verdesardog
154 posts in 2514 days
#1 posted 03-13-2013 01:42 PM
mdf works well for flat panels and DOES take paint well, just make sure to finish sand it first to get rid of all maufacturing lines and oils….
-- .. heyoka ..
View John's profile
John
190 posts in 3486 days
#2 posted 03-13-2013 03:07 PM
I use MDF for painted flat panels in rail and stile doors. I use 3/8” MDF and back cut the panels – I think they make for a more solid door and I prime them with two coats of BIN primer sanded between each coat then prime and paint. Makes for a real nice smooth, hard surface. Be sure to prime all edges of the panels before you assemble the door. The BIN dries in about 15 minutes so work fast and you can sand it and apply all the prime coats in one day.
-- John, Long Island, NY
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1975 days
#3 posted 03-13-2013 03:29 PM
+1 john I use 3/8 mdf and mdf core venereed for flat panels. I have also done raised panels from 3/4 mdf. It takes a tad more primer and sanding, but they paint quite well.
-- Who is John Galt?
View Loren's profile
9934 posts in 3550 days
#4 posted 03-13-2013 03:52 PM
I’d recommend seeing if you can get 3/8” MDF
and then cut a 1/8” rabbet in the back so the
back of the panel is raised flush with the back
of the frame. It looks better, imo.
View waho6o9's profile
waho6o9
8099 posts in 2479 days
#5 posted 03-13-2013 04:07 PM
MDO, medium density overlay, takes paint better imo.
MDF will work as well, if you like working with that stuff.
