my bandsaw switch problem
Forum topic by SCOTSMAN posted 03-12-2013 08:42 PM 1679 views 0 times favorited 8 replies Add to Favorites Watch
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3585 days
03-12-2013 08:42 PM
I bought a new bandsaw a few years back it is a big Italian job.anyway it has a punch type dead switch which stops the machine I.E you hit it and rotate it to release then you switch on a push switch green lit up button to restart it.It has also a kid safety lock into which you can fit a small padlock to keep anyone else away from it when not required.Recently I have had problems getting the green light push switch to start the machine and have to fiddle with the safety switch first now the new problem is Whenever I release the red puch switch the machine comes straight on.It still works but it should be turned on with the green lit up push switch not on release of the red puch switch which as said when you rotate this so it comes back out it is switching on.Can anyone help do I maybe need a new green switch.It all come apart with six screws for getting into I removed the six screws but it looks complicated and I put it back together til I speak to someone any help or advice would be most greatful???? Alistair
8 replies so far
View PASs's profile
PASs
595 posts in 3098 days
#1 posted 03-12-2013 09:19 PM
Pictures….need pictures…the approach, the getaway, the Northeast corner…with circles and arrows….
What is the manufacturer (Laguna?) and model number?
Can you contact them and get support?
I went to the Laguna site and looked at a couple of manuals…but couldn’t see anything that would give a possible explanation.
I’ve had internal springs break in some switches which caused similar symptoms.
What sounds weird is that it sounds like the kill switch has malfunctioned/broken as well.
So although unlikely it almost sounds like both the kill and start switches have malfunctioned.
Unless you or someone you know has worked on switches it sounds like time for new ones.
Of course if they don’t work you can always take them apart before you replace them just to see if it’s an obvious fix.
I had a switch stop working once because it got sawdust in it….put a dust-tight cover on after I replaced it.
-- Pete, "It isn't broken, you just aren't using it right."
View needshave's profile
needshave
175 posts in 1959 days
#2 posted 03-12-2013 10:07 PM
Alistar,
Who manufactured you’re band saw? The way you are describing it, sounds like a MiniMax. If so, the switch box should be covered with a clear flexible cover to keep dust out of the contacts. If it is one and the same, I can open mine up and see if I can help you. I believe the push buttons are merely operating a rocker switch inside the dust proof box. I have found Mini-Max to have a stellar customer service department and they will be happy to help you.l
View REO's profile
REO
928 posts in 2074 days
#3 posted 03-13-2013 01:03 AM
sounds like the start switch contacts are closed all the time. the stop switch stops it because the contacts open when you push the switch and they stay that way because it has to be rotated to let them close. the start switch is in series with the stop switch contacts.
TopamaxSurvivor
18271 posts in 3676 days
#4 posted 03-13-2013 04:27 AM
Do these switches operate a magnetic motor starter or are they manual and interlocked with one another?
SCOTSMAN
#5 posted 03-13-2013 07:56 PM
I’ll check it tomorrow and let you have a few pics yes it does have a kind of dust membrane protector.Thanks so far guys. Alistair
View JesseTutt's profile
JesseTutt
854 posts in 2110 days
#6 posted 03-13-2013 08:29 PM
Electronics stores sell a spray called “Contact Cleaner” intended to clean switches. Open cover up and spray the innards of the switch. Give it a few minutes to dry and try it. Make sure that the electricity is turned off first.
View lew's profile
lew
12061 posts in 3755 days
#7 posted 03-13-2013 09:17 PM
Alistair,
Even with the dust membrane, there can be a build up inside the switch. Remove the cover and try compressed air to blow out the dust. Might just fix it.
SCOTSMAN
#8 posted 03-13-2013 09:18 PM
HERE IT IS A SAGITTARIO
http://img.photobucket.com/albums/0903/tybachdai/shop%20pictures/ee5dbcb8.jpg
