Glue?
Forum topic by Kiersten posted 69 days ago 311 views 0 times favorited 11 replies Add to Favorites
View Kiersten's profile
Kiersten
35 posts in 189 days
69 days ago
Topic tags/keywords: glue question
Ok, Lumberjocks. I need some help!
We’re having my daughter’s sixth birthday party, “Grace’s Build Your Own House For A Stuffed Animal or Webkin So Long As It’s Not a Big Stuffed Animal” Party. I’m cutting my scrap wood into house parts. For many reasons, nails are out so I’m looking for recommendations for glue that sets up quickly, won’t instantly glue their fingers together, and is clear.
Awhile back, Grace received a woodworking kit as a gift and the glue that came with the set was THE BOMB! It was clear and not as runny as Titebond or Elmer’s Woodglue.
Any suggestions? Thanks!!
-- Kiersten, Los Angeles, www.modmomfurniture.com
View lew's profile (online now)
lew
1750 posts in 292 days
69 days ago
I don’t know about the glue, but you’re going to need some pretty big invitations to get all that on one card!
Maybe the glue was DAP OneStick from the Borg.
Lew
6716 posts in 388 days
69 days ago
You could use hot glue but it sets quickly but a bit milky. Although you would not let the little ones use the glue gun.
Kiersten
69 days ago
Thanks, Grumpy and Lew! I’ll look up the DAP onestick from Borg. And I was initally thinking hot glue but then I realized I’d have to hot glue each piece for all 8 kids. UGH. But you’re right Grumpy, that’s a very good glue for what we’re about to attempt.
View Rick247's profile
Rick247
161 posts in 80 days
69 days ago
Double back tape for starters…...sticks to the kids fingers and they will have a blast. When they go to sleep you can take it apart and glue it so it will last forever….
-- God will match you to the size of your Destiny… http://www.etsy.com/shop.php?user_id=6514763
View Steelmum's profile
Steelmum
198 posts in 499 days
68 days ago
If you use glue and just wipe the stuff up. You can let the kids paint the project. Lots of newspapers, picnic table, cheap brushes and camera. Be sure to tell parents NOT to put good clothes on them. I have done this with grandchildren. You WILL need a grownup helper. I did use a brad gun. I let them “help’ one at a time. We did bird feeders. It was fun.
-- Berta in NC
View JAshcroft's profile
JAshcroft
13 posts in 69 days
68 days ago
I have used the DAP onestick and agree with Lew and Grumpy. It’s easy to work with. I still have some left over for upcoming projects similar to what you are doing.
-- Very "Green" to woodworking. Start slow, then taper off......
Kiersten
68 days ago
Thanks, everyone! And Steelmum, I like your idea too! Those are some lucky grandkids! I think I’ll test out the DAP onestick.
View Michael Brailsford's profile
Michael Brailsford
193 posts in 130 days
68 days ago
I would suggest titebond III and use masking tape to hold it together. If its a little runny thats OK the kids will love it.
-- Michael A. Brailsford
View darryl's profile
darryl
986 posts in 863 days
68 days ago
I helped my daughters kindergarten class make birdhouses a while back. Those kits had pre-drilled holes for the nails which made life easier. the only person I saw walk out of there with sore fingers was me! I got wacked with the hammer more than once. I think my daughter even got me twice!
good luck with that project!
-- ~ www.darrylmasterson.com ~ www.woodworkingdungeon.blogspot.com ~
View DaytonB's profile
DaytonB
80 posts in 403 days
68 days ago
Try Titebond molding glue. It’s thicker and has more tack than regular titebond. I don’t think I’ve seen it at Home Depot but you should be able to get it a Lowes, they have a better glue selection.
You might also try Craft or fabric glue, from Hobby Lobby or Wal-Mart, it is much thicker with more tack than regular white or yellow glue, and it really doesn’t run at all. I bet it was some form of craft glue that was in your Daughter’s Kit.
Hope this helps
PS you should consider nails in the crucial spots, kids LOVE to beat on things and you could overly supervise this process. Just worn their parents so they know what’s going on. : )
Have fun, should be a blast for the kids and a hair pulling experience for you :-p
View Alejandro Galo Moreno's profile
75 posts in 151 days
68 days ago
I see a lot of suggestions about glues. So I propose thinking in another way: could you tie the parts together using holes and some rope? Clean and safe, may be a little ¿jamy? (does this word exist).
-- Alejandro Moreno, CANARY ISLANDS
Bookmark And Share This Page
