bandsaw
« back to Scrollsawing forum
Forum topic by tonymc046 posted 03-12-2013 06:00 PM 926 views 0 times favorited 3 replies Add to Favorites Watch
View tonymc046's profile
tonymc046
1 post in 2135 days
03-12-2013 06:00 PM
hi new guy here looking for help i am restoring a inca bandsaw342186 and having trouble keeping the blades on the wheels the wheels ar perfect running through and i fitted new tires flat i have tried 1/8 3/8 1/2 blades but they wont stay on the wheels when adjusted should i fit crowned tires as i have been told that inca only uses flat tires please help tony
3 replies so far
View Loren's profile
10477 posts in 3882 days
#1 posted 03-12-2013 07:16 PM
INCA saws use flat tires. It takes a while to get the
hang of tracking a blade on an INCA 340, but unless
the saw has been damaged, it should track well
once you figure it out.
Try a 1/2” blade to start and bring in up to tension,
then rotate the wheel by hand and adjust the
wheel tilt knob until the blade tracks evenly.
Because the tires are flat, the INCA is more
sensitive to adjust but with practice you’ll get
the hand of it. Rotate by hand many times
before running a blade under power.
View Surfside's profile
Surfside
3389 posts in 2407 days
#2 posted 03-12-2013 09:25 PM
Inca has flat wheels so blade is not centered on the wheel . It runs along the front edge of the tire . Use urethane tires.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View Bayman's profile
Bayman
7 posts in 2551 days
#3 posted 04-21-2013 08:57 PM
Did you get it to work…
