Freud LU87R - why can't it cut under 3/4"
Forum topic by cagenuts posted 03-11-2013 07:59 PM 1467 views 0 times favorited 4 replies Add to Favorites Watch
View cagenuts's profile
cagenuts
36 posts in 2123 days
03-11-2013 07:59 PM
Topic tags/keywords: blade
Would anyone care to explain as why the Freud LU87R010 has a minimum wood thickness specification of 3/4”? Is it perhaps something to do with the tooth design?
I can’t tell much of the differences with that of the glue line rip blade except of course the 30T TCG teeth.
Thanks.
-- Weekend Wood Wrecker
View knotscott's profile
knotscott
7871 posts in 3278 days
#1 posted 03-11-2013 08:07 PM
There’s no reason you can’t cut 3/4” with the LU87, but it’s firmly in the range of blades that will leave a cleaner cut…..LM75, LU83, LU86, LU88, P410T Fusion, along with dozens of models from other brands in the 30T to 60T range.
View MNgary's profile
MNgary
296 posts in 2319 days
#2 posted 03-11-2013 09:18 PM
To prevent moving the board too far under the next tooth before the later tooth begins cutting wood. If you place a quarter inch board adjacent the blade when the blade is raised, you’ll see how it can fit between the teeth.
-- I dream of the world where a duck can cross the road and no one asks why.
View bondogaposis's profile
bondogaposis
4596 posts in 2254 days
#3 posted 03-11-2013 09:39 PM
To cut thinner stock you need more teeth. MNgary has the right idea. The thinner the stock it the more problematic and rougher the cut.
-- Bondo Gaposis
cagenuts
#4 posted 03-12-2013 06:41 AM
Ah thanks guys, so it’s the tooth design that’s determines this.
