DC filters
Forum topic by MrRon posted 03-11-2013 07:05 PM 1863 views 2 times favorited 20 replies Add to Favorites Watch
View MrRon's profile
4675 posts in 3178 days
03-11-2013 07:05 PM
Topic tags/keywords: question
Has anyone thought about using automotive type air cleaners in place of cartridge filters in the return on a DC?
20 replies so far
View DIYaholic's profile
19582 posts in 2610 days
#1 posted 03-11-2013 07:43 PM
There have been several threads here, that use semi-truck air filters for their DC. I don’t have a link, but a search should work.
View b2rtch's profile
4851 posts in 2983 days
#2 posted 03-11-2013 07:53 PM
The problem with doing that is that in a wood shop to need to filter 0.5 micron dust,
I do not know that truck or heavy equipment will do that.
In addition these filters are not cheap.
You need HEPA or Merv 15/16 filters , they are not cheap.
The worse thing you can do to yourself is having a false sense of security using filters that do not in fact filter the fine dust.
-- Bert
View upinflames's profile
217 posts in 2097 days
#3 posted 03-11-2013 11:10 PM
MrRon, This is what you are looking for . You can catch these on sale at a Kenworth or Peterbilt dealer for around fifty bucks. They will work on a DC, these things filter a massive amount of air going into a $30 – $60,000.00 engine, talking near 100% filtration. Just a small amount of dust, dirt or debris is expensive. Now this comes from owning several trucks, the last rebuild I did on a engine was $20,000.00.
View johnstoneb's profile
2819 posts in 2107 days
#4 posted 03-11-2013 11:20 PM
1 Tablespoon of dust will ruin a diesel engine. Truck and tractor filters filter in the 2 to 3 micron area. I have rebuilt a lot of engines that had filters that had a pinhole or the seal wasn’t seated properly.
-- Bruce, Boise, ID
View Kwit's profile
103 posts in 1894 days
#5 posted 03-11-2013 11:58 PM
Here’s the forum link to this question
If you search the LJ forums for “Donaldson” filters – you will get some info on the subject
I contemplated it – but bought a Wynn Nano anyway – happy so far – still experimenting
-- don't talk about it - be about it
View shipwright's profile
7939 posts in 2733 days
#6 posted 03-12-2013 01:44 AM
I used Donaldson truck filters on my DC reno and they are great. Same nano filter ratings as Wynn, just a lot cheaper.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View GT350's profile
362 posts in 1916 days
#7 posted 03-12-2013 04:03 AM
I built this dust collector several years ago, it works great but I may go with a larger filter made for the dust collector.
View Scott C.'s profile
Scott C.
158 posts in 1986 days
#8 posted 03-12-2013 01:59 PM
I was looking into the Donaldson filters, I couldn’t find anything that listed the merv rating, micron level of the filtering, or the surface area of their various filters. Also, it seems only the blue ones are nano? Can anyone confirm this?
-- measure twice, cut once, swear and start over.
#9 posted 03-12-2013 02:49 PM
I looked in the past at Farr filters as I know them for many years and I work with them today.
I could not find filters filtering to 0.3microns.
-- Bert
View hairy's profile
2628 posts in 3467 days
#10 posted 03-12-2013 04:35 PM
I really don’t know the answer, but I have a few thoughts on it. I would like to know more.
Air flow through a truck filter is opposite of how air flows through dust collectors. On a truck the air enters the filter element from the outside and exits through the center. On a DC, the air enters the filter through the center and exits out the filter element. I really don’t know if this will be a problem, but I have my suspicion. If you use it, and like it, I’m glad for you.
DC filters usually have a means to clean the filter. Mine has a handle that connects to flaps inside the filter. Rotating the handle agitates the filter and gravity does the rest. The truth is , they don’t really work very well. If you disagree,rotate your flaps, take off your filter, take it outside and blow low pressure compressed air , from the outside in, and see what you get. You won’t get that flap with a truck filter.
All the air that gets sucked in the hose must exit through the filter.
With allowance for inflation, that’s my 2 cents worth.
-- My reality check bounced...
#11 posted 03-12-2013 04:48 PM
Looks like truck air filters will work and are a lot cheaper than the ones sold for DC’s. The only thing that concerns me is; when used on a truck engine, the air flow is from outside the filter. In a DC application, the air flow is reversed. Will this make a difference?
#12 posted 03-12-2013 04:59 PM
I had the same question,.
I guess the material the filter is made off , really does care about the the air flow direction.
My concern is truck air cleaners not filtering the finest dust, the dust that really arm your lungs.
-- Bert
View Dallas's profile
3599 posts in 2422 days
#13 posted 03-12-2013 05:05 PM
#14 posted 03-12-2013 05:30 PM
Thank you Dallas, notice that these are not heavy equipment or truck air cleaners.
The post is about automatic type air cleaners used on dust collectors.
I do not know how small a dust particle these filters stop
-- Bert
#15 posted 03-12-2013 05:45 PM
If you look at the pdf files some of them filter down to .02 microns.
Being in the trucking industry for 50+ years I can also tell you that modern air filters filter that much or more, depending on the system. Some have primary and secondary filters.
Look at page 3 of donaldsons truck filters here.
This is found at
