Question for turners again
Forum topic by RussellAP posted 03-11-2013 04:45 PM 830 views 0 times favorited 9 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2188 days
03-11-2013 04:45 PM
I plan on turning square blanks. I plan to leave them square and just hollow out a bowl from them.
I’m concerned about the spinning corners, so I had an idea that might help me keep an eye on where those corners are at when it’s spinning.
Now most people might want to consider the possibility of a seizure by doing this so I’m not endorsing it, but rather asking is anyone has tried this or perhaps something else to keep an eye on those corners while you turn.
My idea is to get a strobe light mounted where it can shine on the corners as they spin. I think it would make it much easier to see where your tool is in relation to the corners.
Any thoughts?
9 replies so far
View MNgary's profile
MNgary
296 posts in 2319 days
#1 posted 03-11-2013 05:37 PM
I suggest you mount one of the squares, turn on the lathe, and then decide if the strobes are needed. I rely on sight, sound, and feel without accessory lighting, but maybe the strobes are an added plus for you. By sight I include the appearance of the blank in addition to the shavings as they are generated.
-- I dream of the world where a duck can cross the road and no one asks why.
View TheDane's profile
TheDane
5364 posts in 3565 days
#2 posted 03-11-2013 05:40 PM
Russell—I don’t think you’ll need strobe lights … the ‘ghost’ will be visible enough to stay out of trouble.
You’ll be turning a lot of air, so take very light cuts.
RussellAP
#3 posted 03-11-2013 05:48 PM
TheDane, I thought maybe put some white paint on the corners would work. And maybe a line down the sides to keep an eye on them as they turn.
I have a gooseneck light and a halogen mounted just off center to keep water from splashing on it. One is on the front side and one is on the back side. I also use a very powerful led flashlight with a magnetic base which fits will on the tailstock to see inside bowls.
View Kreegan's profile
Kreegan
1452 posts in 2048 days
#4 posted 03-11-2013 06:20 PM
Just stick a piece of blue painters tape on one of the corners. It’ll stick out like a sore thumb. I do this on cole jaws.
RussellAP
#5 posted 03-11-2013 06:30 PM
Great idea Kreegan.
View Cliff De Witt 's profile
Cliff De Witt
130 posts in 2594 days
#6 posted 03-11-2013 06:52 PM
Personally I just keep everything on the side of the tool rest that does not have wood.
Kind of hide behind the bar. You will be able to see most of the wood from the ghosts and way.
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
View bondogaposis's profile
bondogaposis
4594 posts in 2253 days
#7 posted 03-11-2013 06:53 PM
If you go the strobe light route, throw in a disco ball too, ;-), and take pictures.
-- Bondo Gaposis
View REO's profile
REO
928 posts in 1976 days
#8 posted 03-11-2013 07:04 PM
the problem with strobe is that it psychologically reduces the danger. If its not moving its safe. Years ago a fellow I knew thought it was cool to put on demonstrations with a table saw using a strobe. He was a little hard of hearing to start with and with the hearing protection on he couldn’t hear the saw running. He fired up the strobe and turned on the saw, but the ambient light was to bright so he asked someone to turn down the lights. when he turned back to the saw he noticed a little chunk next to the blade. he reached in to flick the piece out of the way with his finger forgetting that the saw was running, and lost a pea sized piece of the end. not that everyone would do that, but the perception of the danger is diminished without a frame of reference through hearing, feeling and sight. Just a little bit of bright color on the corners will help to clarify the boundary.
View mikema's profile
mikema
180 posts in 2488 days
#9 posted 03-11-2013 07:06 PM
I think you will be fine with out the strobe light. I have started out with a few square turnings, and they are easier to work with then you think. You will be able to tell where the corners are while it is turning without the strobe light.
As I am thinking about this, I would think the strobe light would make the turning more difficult. The strobe light would make it seem more discrete where turning is more continuous type movements.
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
