Are hollow core doors really flat? (Use for assembly table)
Forum topic by Bill Szydlo posted 03-11-2013 03:06 PM 5193 views 0 times favorited 9 replies Add to Favorites Watch
View Bill Szydlo's profile
Bill Szydlo
67 posts in 2922 days
03-11-2013 03:06 PM
I am planning on building an assembly table that is adjustable (height). Someone recently recommended I go the hollow core route rather than building a torsion box. I am planning on the width being 36” or 38”. I would use the hollow core door as the core with either 1/2” or 3/4” mdf glued on top and bottom. Before I go to my local big box and start checking each one for flatness I am curious if anyone on this forum has any advice on my planned build. Would it be better to just go the torsion box route?
Thanks,
Bill
9 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3713 days
#1 posted 03-11-2013 03:07 PM
I thought the same thing, but plan someday to do the torsion box.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
117416 posts in 3812 days
#2 posted 03-11-2013 03:17 PM
It’s not a matter of hollow core doors being flat,it’s that their not strong enough for an assembly table.Solid core doors will work fine.
Edit
sorry I missed the part about you wanting to glue mdf to the top and bottom. Why not just glue two sheets of 3/4” melamine together IMO this torsion box Idea is way over rated.
View Bogeyguy's profile
Bogeyguy
548 posts in 2303 days
#3 posted 03-11-2013 03:32 PM
I would use a solid core door. Strong and solid. You can get one at your recycled construction material dealer. Here in Pgh. that is Construction Junction. Not sure if there is one in your area but I would check around. I have one that is 2” thick and I have been using it for at least 25 years.
-- Art, Pittsburgh.
Bill Szydlo
#4 posted 03-11-2013 03:43 PM
I don’t live in Pgh but I am an avid Steelers fan. I live in Mn and will check out the local recycled building material dealer. I assume a solid core door is laminated to stay flat and would be heavier. The reason for the laminated mdc was to add weight. I am going to be building a “jack bench” (http://www.jack-bench.com) with an basic flat top for the top. This design, developed by a local woodworker, uses 2 car/motorcycle jacks to (1) lift the top and (2) lift the entire bench for portability. Since the top is resting on a jack I want to make sure it is very sturdy.
View Pdub's profile
Pdub
924 posts in 3415 days
#5 posted 03-11-2013 04:31 PM
I have some hollow core doors in my house and they tend to twist or bow, depending on the time of year. I live in North Dakota. As stated above, I would look for a solid core.
-- Paul, North Dakota, USAF Ret.
View Loren's profile
10477 posts in 3882 days
#6 posted 03-11-2013 04:53 PM
Well, they tend to be flattish because they are really
built pretty light and inside honeycombed with
cardboard. This does help them stay pretty flat.
I’ve never built a permanent assembly table from
a door, but plenty of times I’ve used a door salvaged
from the trash as an assembly table. Just set up
a couple of sawhorses, put the door on them, then
shim up the low corner and check with winding sticks.
If your door is twisting, screw it to the sawhorses.
For a permanent table with a 3/4” skin on top, I’d consider
adding some sort of adjustment mechanism at the
corners and be aware that for the table to stay flat,
it needs to be evenly supported so at least one leg
should be adjustable.
Bill Szydlo
#7 posted 03-11-2013 05:13 PM
Thanks for all the help, it looks like a solid core door is the way to go. Next question, if I put a piece of mdf on one side only will it affect the tendency of the door to warp? I know if you veneer a panel you should do both sides for equilibrium, do you think it will affect a door the same way?
woodbutcherbynight
5824 posts in 2644 days
#8 posted 03-12-2013 05:02 AM
Bill Szydlo A friend tried that and it warped the first severe temp change. I have done as a1Jim posted, glued two mdf boards together and if you want a nice surface put laminate on it, thicker stuff though not the box store version it is way too thin. Currently have 3 workbenches with this type of top and they all have been around for 10 years or more and are still flat.
View MrRon's profile
MrRon
5261 posts in 3478 days
#9 posted 03-13-2013 05:08 PM
Torsion boxes are a pain to build. Their only advantage is light weight. Go with MDF. Solid core doors are made with a particle board core (similar to MDF), so don’t pay extra for a SC door when cheaper MDF will work as well.
