board edge cleanup -- which plane to use?
« back to Hand Tools forum
Forum topic by dpjeansonne posted 03-11-2013 03:05 PM 1114 views 0 times favorited 6 replies Add to Favorites Watch
View dpjeansonne's profile
dpjeansonne
72 posts in 3448 days
03-11-2013 03:05 PM
Topic tags/keywords: hand planes milling finishing joining plane
I am just getting into using hand planes in my shop and find them interesting, satisfying, and frustrating.
After edge jointing on a power planer or ripping on the table saw, which plane is best to use to remove the mill marks?
I think it could be a block, a #4 smoother, a #5 jack, or even a #8 ?
Would like various opinions and the reasons behind the selection.
Thanks in advance for sharing your experiences.
-- Cajun Don, Louisiana
View chrisstef's profile
chrisstef
17796 posts in 3241 days
#1 posted 03-11-2013 03:13 PM
A #7 or #8 jointer plane is typically the go to for edge dressing. The length of the plane allows it to keep a flat reference over a longer portion of the board where as a smaller plane may ride the ridges.
View JayT's profile
JayT
6002 posts in 2445 days
#2 posted 03-11-2013 03:17 PM
interesting, satisfying, and frustrating Totally agree with that sentiment.
Depends on the desired final result. For most applications, I would use the longest one in your arsenal that you can control on the width to help keep everything straight. I usually use my 608, but will also use a 606 on edges that are 3/4” wide or less because it is easier to control (don’t have a #7 size and not sure I need one). If there are multiple boards, then I clamp them all together and use the 608 to do multiple edges at one time. Your situation is different however—I do not have a power jointer, so the hand planes are used for all jointing.
If it is just to clean up milling marks on a final exposed surface then a smoother set to take very light shavings would be fine, just ask Paul Sellers—he can use a #4 for almost anything. Of course, he is far more talented and experienced than me.
View bondogaposis's profile
bondogaposis
5148 posts in 2585 days
#3 posted 03-11-2013 03:18 PM
#7 or #8 jointer plane will do the best job knocking off the high spots.
-- Bondo Gaposis
View Don Broussard's profile
Don Broussard
3701 posts in 2486 days
#4 posted 03-11-2013 03:19 PM
+1 on chrisstef’s recommendation. I have both a #7 and a #8C. For edge jointing, I use the 8 since it has a straight-edged iron, while the #7 has a cambered blade.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View sikrap's profile
sikrap
1121 posts in 3593 days
#5 posted 03-12-2013 12:47 AM
Assuming you got a straight edge, any plane will work. Most of us use a 7 or 8, but you need to be careful to keep the plane square. You can attach a fence to the side of a plane (Veritas makes a magnetic one) or you can look around for a Stanley 95. The 95 is a small plane designed especially for edge jointing, but it will only work on boards up to 3/4” thick. If you decide to use the tip from above about doing multiplr edges at once, make sure you have the edges that will be glued together next to each other. That way, it doesn’t matter if you put a slight bevel on the board.
-- Dave, Colonie, NY
View Dallas's profile
Dallas
3599 posts in 2721 days
#6 posted 03-12-2013 12:53 AM
A good sharp card scraper will get rid of the mill marks about as easily as a plane and won’t tend to dig in too much.
If it comes off the jointer or planer or a well tuned table saw everything should be parallel, plumb and true.
