Need an opinion
« back to Woodturning forum
Forum topic by RussellAP posted 03-11-2013 12:52 AM 1082 views 0 times favorited 12 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2254 days
03-11-2013 12:52 AM
Topic tags/keywords: bowl sapele
I turned this Sapele bowl earlier. I like the wood for turning but it’s very lack-luster as wood goes. I didn’t like it because it looked like a brown dog food dish. So I decided to give it a pedistal, but I’m uncertain how it looks with the walnut base.
Initially before I made it, I was convinced that either cherry or walnut would work, so after thinking about it way too much and my wife’s reaction, (you know when your wife is just saying she likes something, but really just to make you happy). So I thought I’d throw it out to you trustworthy jocks.
Which one?
Original bowl without base.
With walnut base.
12 replies so far
View Marcus's profile
Marcus
1163 posts in 1987 days
#1 posted 03-11-2013 12:55 AM
I think it needs something else too. My first reaction was exactly what you said, it kind of resembles a dog bowl. I’m not sure that base fits with it well either. Because of the contrasting woods and styles, it looks like an afterthought.
View Reddog's profile
Reddog
17 posts in 1930 days
#2 posted 03-11-2013 01:06 AM
I think with the shape of the bowl, which I kind of like, that a shorter base of walnut that was wider than the bowl would look good. Almost like a plate beneath it but maybe wrapping up the side just a bit. The original bowl looks very solid and grounded with the pyramid like sides. But the current base doesn’t carry that theme through. Maybe a short base with the same outward taper that the Sapele could nest in? Don’t give up on it, I think it’s a good form it’s just not finished yet.
View lblack2x4's profile
lblack2x4
23 posts in 1871 days
#3 posted 03-11-2013 01:12 AM
I have to agree nether the bowl nor the base work. I think you can fix it though one thing would be to sand the bottom and glue another peace of Sapele to the bottom with this you could turn a new shape perhaps round it over and make it look like a calabash bowl? if your worried about how the joint will look put something in between and make it look cool. I think this peace is still very salvageable. good luck
View Brandon's profile
Brandon
4152 posts in 2919 days
#4 posted 03-11-2013 01:18 AM
That has got to be the nicest dog bowl around!
-- "hold fast to that which is good"
RussellAP
#5 posted 03-11-2013 01:26 AM
So far it’s against. I knew my wife was trying to make me feel good. I took the base off. I’ll order a sapele spindal blank and work out a matching base or if they have it a platter under it like reddog said. I’d like to find a 10” square sapele blank and turn the square with a round fitting for the bowl to fit into and just turn the bottom of the platter up slightly. I love those square bowls these guys have been doing. Can’t find square blanks online though.
RussellAP
#6 posted 03-11-2013 01:36 AM
I emailed Got Wood and asked them if they could cut me a 10”x10”x2or3” square blank for a square platter to put it on. I don’t know if I should make it permanent or not, any opinions. Glue on the platter or not?
View Mark828's profile
Mark828
95 posts in 1896 days
#7 posted 03-11-2013 03:16 AM
Agreed, No base looks like a dog bowl and I kinda like the second but only cause it looks like a squished lamp. To tell you the truth, I was looking for a small desk lamp and that would be classy. Problem solved, carve it as thin as possible and make it a lamp.
View REO's profile
REO
928 posts in 2042 days
#8 posted 03-11-2013 03:27 AM
just put a bead around the base of the existing bowl to break up the long straight side. make it a generous bead though.
View waho6o9's profile
waho6o9
8167 posts in 2544 days
#9 posted 03-11-2013 05:11 AM
Sapele dog bowl works for me. Put it on Etsy that way.
Why mess with perfection?
Smitty_Cabinetshop
15283 posts in 2586 days
#10 posted 03-11-2013 05:23 AM
Turn a lid for it…
View Jack Gaskins's profile
Jack Gaskins
46 posts in 2982 days
#11 posted 03-15-2013 11:59 AM
Well, IMO the bowl shape is off. I am in the camp that likes bowls to have an open diameter not a closed diameter. A strainght or inward rimmed bowl will allways look like a dog bowl I think. And I am in the other camp that thinks pedestals are used on open bowls as well and that the pedestals should be very skinny and long with some detail in them. Short fat pedestals just are for me. Good effort though.
Jack
-- USAF Ret. 2006
View ScrubPlane's profile
ScrubPlane
190 posts in 2163 days
#12 posted 03-17-2013 02:57 AM
The base does look too contrived a solution…should you go that route, however, I’d recommend either a very dark walnut or perhaps an ash.
That said…I don’t care for the pedestal solution. I’d recommend you re-mount the bowl to your lathe and try re-shaping it.
