Darkening wood
Forum topic by Monte Pittman posted 03-11-2013 12:52 AM 1093 views 0 times favorited 7 replies Add to Favorites Watch
View Monte Pittman's profile
Monte Pittman
29226 posts in 2335 days
03-11-2013 12:52 AM
Topic tags/keywords: question
When making mugs, I know a wood like cherry darkens in time. Is there a way with UV or IR lights to make the darkening process happen faster?
7 replies so far
View juniorjock's profile
juniorjock
1930 posts in 3763 days
#1 posted 03-11-2013 12:58 AM
Just lay your stock out in the sun. You’d be surprised how dark it gets in a small amount of time. Just keeping turning so you don’t burn on one side…...
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#2 posted 03-11-2013 02:18 AM
Monte, Look at my “Arkansas Cherry Coffee Table” that’s what it looked like after BLO and 3 days in the sun. If you do that, pick a WARM day and keep checking as Blo will ” bleed” in the sun.
View sras's profile
sras
4797 posts in 3127 days
#3 posted 03-11-2013 02:52 AM
Check this posting out. I used his method and posted it here .
Monte Pittman
#4 posted 03-11-2013 02:59 AM
Excellent information. Thanks guys.
View Loren's profile
10385 posts in 3645 days
#5 posted 03-11-2013 03:06 AM
You can fume oak with ammonia.
Monte Pittman
#6 posted 03-11-2013 03:08 AM
I should try that as well.
View cosmicturner's profile
cosmicturner
403 posts in 3393 days
#7 posted 03-11-2013 03:41 PM
Fuming requires a stronger ammonia than the type you can buy over the counter you need the stuff that can and will kill you if you are not careful….I have done fuming but never tried cherry usually it is white oak going for a true mission style finish….that is how they use to do whole rooms at once sealed up and fumed then aired out…
-- Cosmicturner
