| Forum topic by EWJSMITH | posted 75 days ago | 442 views | 0 times favorited | 10 replies | ![]() |
75 days ago |
Hi all, I have another basement bar job coming up and I’ve put together my plans and present to client – they are happy so I’m good to go – got my cutlist do so next is purchase of materials. For my previous work, I’ve always built my bars using a cabinet construction approach and I’ve used 3/4” birch ply. I’m wondering if that’s overkill? The bars have been rock solid and heavy but I’m looking for input on my selection of carcass material. Anyone care to chime in? Is 1/2” too flimsy? Is 3/4” excessive? Is 5/8” a nice medium? Looking forward to your thoughts on this. Cheers! |
10 replies so far
#1 posted 75 days ago |
Personally, I would use 3/4”, but I know that I overbuild. Depending on the design, 1/2” would probably be sufficient in most areas and use 3/4” in those areas that will likely see more stress. FWIW -- Art |
#2 posted 75 days ago |
I always use 3/4” Baltic birch for my cabinet carcasses. I figure the small cost difference between 3/4” and 5/8” or 1/2” is insignificant compared to the time I invest in building them, and prefer to overbuild. Plus, it seems like a lot of hardware is made for the standard 3/4” thickness. More material there for dados, rabbets, etc. as well. -- John, BC, Canada |
#3 posted 75 days ago |
It depends how you are set up. 3/4” is easy to source 5/8” is sometimes used in frameless. Usually melamine. 1/2” can work too, but I’d recommend face frames Weight is the major factor, imo. I’ve read about cabinets |
#4 posted 75 days ago |
“I’ve put together my plans and present to client – they are happy so I’m good to go” Hmmm…I am not sure how much construction detail you showed your client but I would build it just like you presented your proposal. -- Handcrafted by Mike Henderson - Channelview, Texas |
#5 posted 75 days ago |
It depends, to me, on the design and span sizes. Is it curved, L shaped, rectangular? Will it be free standing or against a wall? Is it a service bar in the corner or one that will have 6-8 people sitting at it? Are you using face-framed panels, covering it with mirrors or carpet, creating a pattern using veneers? Would it be possible to see the concept drawing you showed your client? -- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse |
#6 posted 75 days ago |
Having built countless bars over the course of my journey and my journey isn’t over yet so before I comment I want to say this. Even though architects, engineers and for that matter, designers, and the ever naive “home owner” all of which have are the “client”, all tend to avoid liability therefor rendering somewhat generic drawings similar or worse then “Sketch Up” doesn’t preclude taking the mystery out of doing legible shop drawings and joinery methodology, sections where needed. and clear concise specifications to cover your own ass. Integrity rules the day I HATE doing things twice so I tend to be proactive instead of reactive and will continue to error on the side of caution so if your asking, I tend to use 3/4” plywood but I stress that this isn’t always the case as you provide little in the area of conceptualization of what your trying to build ?…….often, shop drawings done by a pro can save sooooooooooooooo much grief : )) and am somewhat appalled by the amount of professional shops out there, who haven’t the foggiest idea, how things are done, and are surprised to be greeted with ugly litigation, where the balance of a bank account decides the outcome. Chiming in -- "Good artists borrow, great artists steal”…..Picasso |
#7 posted 75 days ago |
perspective
keg cooler -- "Good artists borrow, great artists steal”…..Picasso |
#8 posted 74 days ago |
I use ½” on most drawers, but for frames and big drawers I use ¾”, and even at that I often end up with detail that provides more stiffening (face frames or rear frames). Especially for built-in stuff, people will end up climbing on it (even if that’s “let me put a foot here off this ladder so I can reach…”). Now I’m doing most of my work for my house, and my goal is to do everything I built with an expected 50 year lifespan that will never bug me again, but if you’re thinking about the long-term happiness of your clients… -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#9 posted 74 days ago |
Thanks guys. I’m 99.9% certain I’ll be using 3/4 sheet goods again but I was just curious as to what others have as an opinion on this matter. Below are some sketchup drawings done to show what I plan on building. The section with the shelves on the wall is one sheet of material screwed to the wall with the shelves attached and right now, this is up in the air. The client isn’t sure if they want it yet or not. But the rest of the design remains the same. I plan on building this in 5 separate smaller cabinets (largest being 36” wide which is the one against the wall) and then all cabinets joined together on site. Same as what I did for my last build.
#10 posted 74 days ago |
The places I’d consider thinner goods are maybe the wine bottle area, and, if the Sagulator calculations came out right for whatever the client wanted to store there, the shelves to the left of that cabinet and drawer area (though I’d be more comfortable with ½” for those shelves if that divider to the left of them had a bottom and was strong enough to put the ends of the shelves in tension). And I’d probably double-up on both of those counter-top spans. And I think you could probably get away with something thinner on those big face areas, though I’d be concerned that someone sitting on a stool there would kick those panels and feel how thin they were if they were too thin. Given all the trim work there, if it wasn’t going to get kicked you could almost use ¼” ply (I use that for cabinet backs), but… -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15807 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
