Creating a camber on a plane blade?
« back to Hand Tools forum
Forum topic by ScrubPlane posted 03-10-2013 09:36 PM 1310 views 0 times favorited 7 replies Add to Favorites Watch
View ScrubPlane's profile
ScrubPlane
190 posts in 2066 days
03-10-2013 09:36 PM
Topic tags/keywords: blade sharpening
I’ve been exploring and using hand planes more and more over the last two years but could use advice on cambering the blade. I utilize a granite stone, sandpaper, and the Veritas honing gauge to sharpen my blades…and this method does get them ‘scary sharp’.
I have ‘rescued’ an old #5 I want to turn into a ‘tweener’ plane to use after my traditional scrub plane but before my #8.
Any advice on how to properly camber the blade would be appreciated.
File, grinder…before or after sharpening, etc?
Much appreciated…
7 replies so far
View mds2's profile
mds2
310 posts in 1815 days
#1 posted 03-10-2013 09:46 PM
I use a grinder. I made a bunch of radiused templates on my bandsaw out of hardboard. . I take the template with the radius I want, put it on the back of the iron, draw a line with a sharpie, then take it to the grinder.
View paratrooper34's profile
paratrooper34
915 posts in 2822 days
#2 posted 03-10-2013 10:07 PM
mds2 has it right, that’s the easiest way for me to do it also. When honing the blade with the Veritas jig, it helps to have the camber roller on it rather than the straight one.
-- Mike
View bondogaposis's profile
bondogaposis
4524 posts in 2222 days
#3 posted 03-10-2013 11:07 PM
I use md2’s method also.
-- Bondo Gaposis
View Handtooler's profile
Handtooler
1492 posts in 2003 days
#4 posted 03-10-2013 11:23 PM
For a 2” blade on a #5 Groz what radius do you perfer for a scuub plane use and approxamate how wide/large an opening of mouth set by the frog position? It currently does quite well set-up as a smoother with quite thin curls (0.003-4”). I would like to flatten hard dry Pecan which is too wide for my 6” jointer before using a power planner.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
paratrooper34
#5 posted 03-10-2013 11:29 PM
Handtooler, I use a 12” radius on my jack plane and I keep the mouth open all the way.
-- Mike
Handtooler
#6 posted 03-11-2013 12:12 AM
Thanks Paratrooper34!
ScrubPlane
#7 posted 03-11-2013 12:45 AM
Great suggestions all…much appreciated.
