scraper plane problem
« back to Hand Tools forum
Forum topic by jdh122 posted 03-10-2013 06:32 PM 995 views 0 times favorited 8 replies Add to Favorites Watch
View jdh122's profile
jdh122
1012 posts in 2817 days
03-10-2013 06:32 PM
I wonder if anyone can help me. I recently acquired a Veritas scraper plane and have been trying to use it for final wood smoothing following a no.4 smoothing plane. I’ve set the plane up following their instructions (to the best of my abilities), but it leaves a pretty deep ridge on one side of the plane. It’s not a ridge in the blade itself, comes from the setup, but when I seat the blade it’s flat. Rather than leaving a better surface than the smoothing plane it’s actually worse, which shouldn’t be. Maybe I’m putting too much camber in the plane or have the blade pitch wrong (the instructions call for 5 degrees off vertical).
I use both cabinet and card scrapers regularly with no problems but haven’t been able to figure the scraper plane out, and any help or tips on their use would be appreciated.
Thanks.
-- Jeremy, in the Acadian forests
8 replies so far
View DKV's profile
DKV
3940 posts in 2504 days
#1 posted 03-10-2013 06:52 PM
What did Veritas support say?
-- This is a Troll Free zone.
View paratrooper34's profile
paratrooper34
915 posts in 2951 days
#2 posted 03-10-2013 07:06 PM
Gonna go out on a limb here, I am guessing they are closed on Sundays? Maybe he would like a little help from some people who can help him out on a Sunday? Get a life and stop hassling everyone. Contribute or move along.
jdh122, sounds to me as though the blade is higher on side than the other. That would make one of the corners of the blade dig in deeper than the other.
-- Mike
View nwbusa's profile
nwbusa
1021 posts in 2286 days
#3 posted 03-10-2013 07:13 PM
Yep, LV is closed Sundays. I own that plane and I haven’t encountered the problem described. Is it the corner of the blade gouging the wood? Maybe knock the corner down with a file?
-- John, BC, Canada
View Tsmutz's profile
Tsmutz
9 posts in 1903 days
#4 posted 03-10-2013 08:59 PM
I have the same plane and it’s one of my favorites. But it has a learning curve.
First put a 1/16” radius on the corners of the blade to avoid leaving tracks on your workpiece.
Second, turn a small burr and use the blade as a hand scraper to find the natural cutting angle.
Make sure the camber adjuster is backed out, and adjust the blade holder to the cutting angle you found using the blade by hand.
Drop the blade in the plane with the body resting on your bench, now put your index finger on the top of the blade and push down with about the amount of force you use for a mouse click and tighten down to lock knob.
Add a little camber if needed.
Hope this helps, it took a while but I really love this plane now.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3585 days
#5 posted 03-10-2013 09:01 PM
send it to me for thirty years free assesment. Alistair
View Don W's profile
Don W
18715 posts in 2567 days
#6 posted 03-10-2013 09:36 PM
Tsmutz gave some good advice. I’ve got the same plane and never had the issue, but then I never read their instructions either.
It sounds like one side of the blade is just digging in. Also Make sure your not just pushing down on the one side.
jdh122
#7 posted 03-10-2013 10:33 PM
Thanks for the advice everyone, especially Tmutz. I re-sharpened the blade and turned the burr (before seeing your message) and it worked better, but I think I’ll put the small radius on the corners like you suggest (just like with a smoothing plane).
18615 posts in 4160 days
#8 posted 03-11-2013 12:38 PM
a good point re: customer support—Lee Valley/Veritas has the best customer support!
