Question for box makers when it comes to cutting splines.
Forum topic by Blackie_ posted 03-10-2013 04:36 PM 1981 views 3 times favorited 21 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4846 posts in 2415 days
03-10-2013 04:36 PM
I have my first fully mitered box fully closed and glued and is ready for the next step, I’m also still green when it comes to splines so the height of the blade is still in question for me, box walls are 3/8” thick.
The lid is still attached to the box, I’ve not cut it off yet so my question is do I cut the lid off before doing the splines or cut all splines then cut the lid off? Is it a matter of preference?
If I cut the splines with the lid on I can get the lid and the box at the same time only I won’t be able to see if I’ve breached the walls on the inside.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
21 replies so far
View Monte Pittman's profile
Monte Pittman
28133 posts in 2241 days
#1 posted 03-10-2013 04:57 PM
Cut splines before cutting off the top. Helps hold everything together. I have screwed it up the other way personally.
-- Mother Nature created it, I just assemble it.
Blackie_
#2 posted 03-10-2013 05:10 PM
OK yea Monte, that’s what I was thinking and also thanks James, I followed your directions and image and it worked great, thanks just a few more cuts to go.
View Handtooler's profile
Handtooler
1497 posts in 2035 days
#3 posted 03-10-2013 05:10 PM
Great question! I am about to attempt this same type project, so your answers will be of particular interest. James that is very helpful; it’s a great diagram and explains your answer so succinctly. Does one ever desire to breach the ith inside and have an off colored spline show?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Randy63's profile
Randy63
252 posts in 2795 days
#4 posted 03-10-2013 05:11 PM
Definitely keep the box in one piece before cutting your slip feathers. I know what you’re referring too, while techinically they are not splines but slip feathers. You can do a search on this site for either spline jigs and or slip feather jigs and find a multitude of jigs to chose from.
-- Randy, Oakdale, Ca.
View Donna Menke's profile
Donna Menke
616 posts in 4169 days
#5 posted 03-10-2013 05:26 PM
For those of us inclined to calculate: it is the usual A2 + B2 = C2 (squared). So (0.375×0.375) + (0.375×0.375) = the square of the diagonal side. The square root of that number will give you the maximum depth for your blade. I’m sure we all knew that- but I wanted to make sure.
-- "So much wood. . .so little time!" www.woodworks-by-donna.com
Blackie_
#6 posted 03-10-2013 05:51 PM
Thanks Donna, that makes everything come to light :)
Here is an image of my spline / feather jig that I’ve already built just for this task.
View nwbusa's profile
nwbusa
1021 posts in 2189 days
#7 posted 03-10-2013 06:06 PM
Yep, lid on is how I did it.
-- John, BC, Canada
View ShaneA's profile
ShaneA
6889 posts in 2501 days
#8 posted 03-10-2013 06:28 PM
If possible try to use a flat top grind on the saw blade.
Blackie_
#9 posted 03-10-2013 07:19 PM
Yea I came home today from the box stores Lowes and HD best thing that I could find close enough was a Diablo thin kerf 50T combo.
View Boxguy's profile
Boxguy
2533 posts in 2170 days
#10 posted 03-10-2013 08:34 PM
Blackie, cut the splines first. Instead of doing the math, lay one of the brass set up bars the corner at a 45 degree angle. Combine two of them until you get something that looks like it will be just a little short of being as thick as the sides and then use the same bars to set up the height of the saw blade.
Forrest #2 grind for 1/8 inch blades. One of the outside dado blades will do in a pinch.
Don’t use a thin kerf. It is too hard to get the splines that thin.
I’ll add some pictures of the press and the lid technique, but basically leave the top of the box square, add glue and clamp on your top. After the glue dries, trim the edges with a band saw to get them close then bring them flush to the sides of the box with a flush trim http://www.rockler.com/product.cfm?page=16976&site=ROCKLER. router bit. In this case the bearing runs along the side of the box and the blade trims off the overhang of the top. It is important that the trim bit blade be longer than your top is thick so you can trim it to size in one pass.
-- Big Al in IN
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#11 posted 03-11-2013 02:27 AM
That Diablo will cut too narrow of a kerf for an attractive spline (unless your box is REALLY small). It also does not have a flat top grind so won’t cut flat bottoms in the spline kerfs. I’ve used various cheap dado sets but I use my Freud Box Cutter set for all my splines now (flat bottoms, no tearout,stays sharp for a LONG time). You don’t want to widen your spline kerf by making multiple passes (Trust me I’ve screwed this one up before). You can cut the splines before cutting the top off but measure blade height carefully so you don’t go through! Been there, done that too!
Blackie_
#12 posted 03-11-2013 04:54 AM
I plan on taking the diablo back for a refund and heading up to the local woodcraft shop, Andy those box cutters they are 8” not 10? correct?
View Moron's profile
Moron
5032 posts in 3796 days
#13 posted 03-11-2013 05:04 AM
there is nothing like practice
View Gene Howe's profile
Gene Howe
10109 posts in 3331 days
#14 posted 03-11-2013 10:41 AM
An answer to Russell’s question: Yes, there is a reason to cut deep enough to allow the feather to protrude into the interior of the box. For one set, at least. That would be to provide a rest for a tray.
Blackie_
#15 posted 03-11-2013 11:38 AM
Ah, never thought of a feather/spline being used as a tray rest, I’d think they would have to be at least 1/4” for stability and support.
