| Forum topic by HorizontalMike | posted 74 days ago | 755 views | 0 times favorited | 42 replies | ![]() |
74 days ago |
Topic tags/keywords: routing router hand plane tote round-over safety safe I have started making my own hand plane totes and knobs and am wondering about what other LJs feel is the safest method for routing a 1/2in round-over on a new tote? I am not talking about rounding completely by hand. Even Lee Valley references using a router to do this task of rounding over these complex curves on a tote. Please feel free include pictures showing your particular method and feel free to explain why and how, etc. to best do this. You know the old adage, ‘A picture is worth a thousand words’... ;-) Instructions from http://www.leevalley.com/us/html/16j4010k.pdf How can the below image/method be improved upon? -- HorizontalMike -- "Woodpeckers understand..." |
42 replies so far
#1 posted 74 days ago |
In the past when I had to rout small items and I felt my fingers were too close to the bit I’d make a jig to hold the piece. Gives you a lot more control too. From your picture I’d say that was too close for my comfort. |
#2 posted 74 days ago |
Thanks Jeff. That is exactly why I ask the question above about safety. I am looking to see what kinds of jigs others may have made for this particular task in making HP totes safer to round over. -- HorizontalMike -- "Woodpeckers understand..." |
#3 posted 74 days ago |
Mike, I use a 12” wooden hand screw clamp. I have to loosen it/tighten it 4 times on each one, but it keeps my fingers the hell away from that spinning finger eater…. -- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com" |
#4 posted 74 days ago |
Use a clamp. The best are wooden clamps, as they’ve got some mass and sit square to the bit. -- ian | "You can't stop what's coming. It ain't all waiting on you. That's vanity." |
#5 posted 74 days ago |
you can do what Jeff said of just use a wooden screw clamps to hold the tote or buy a small adjustable small part clamp.
-- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#6 posted 74 days ago |
Interesting, I cut out a tote the other day, but haven’t rounded it yet. I considered doing it by hand, but the router method seems quicker and more accurate. I think I might try with just a push paddle. |
#7 posted 74 days ago |
Bam! There goes my first ”Gee, I coulda’ had a V8” moment! Great idea, and simple too! Thanks. BRAINSTORMING: Anyone using a bolted rod through the tote, in any way? Maybe to hold a wedge to square up the top of the tote for the clamp? -- HorizontalMike -- "Woodpeckers understand..." |
#8 posted 74 days ago |
Mike, I could have sworn I had a picture like a1Jim shows on my blog, but its not there. But to be honest though, I free hand it like you show, and sneak up on the cut. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#9 posted 74 days ago |
Kinda slow typing on my first response. You could also just attach a couple sticks with hot glue ,route then remove the sticks, not sure about using a bolt through the tote. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 74 days ago |
Scott, I am thinking that the ‘push stick’ would not be enough. I did a couple totes as posted in the OP and it scared the dickens out of me, and chipped the tote’s toe on the right every time. It sent the tote flying and I was left with my fingers way too close for comfort. This clamp thing is sounding better all the time! That FIRM grip on the tote is the only thing keeping it from flying when it contacts that cutter. -- HorizontalMike -- "Woodpeckers understand..." |
#11 posted 74 days ago |
double stick tape it down and use a trim router by hand. might have to make the hole in the router base a little bigger for the 1/2 roundover bit. you can make several passes if you need to. |
#12 posted 74 days ago |
Jim, -- HorizontalMike -- "Woodpeckers understand..." |
#13 posted 74 days ago |
James101, that also sounds doable, but I don’t currently have a trim router to play with. Maybe this would be motivation to save for one. Hmm… -- HorizontalMike -- "Woodpeckers understand..." |
#14 posted 74 days ago |
That sound like a winner Mike
#15 posted 74 days ago |
Well, I just ran out to the shop and tried the wooden clamp idea on the Zebrawood tote as seen above. I had to finagle with a couple of the cutoff pieces to wedge it properly and even used the end of the tote rod sticking out, to keep it in place while clamping. Cool! Think I may have had the router turned up a bit high as things wanted to burn rather easily, but other than that I feel A LOT SAFER routing these totes with a clamp. Jim, I sure appreciate the ideas folks! They helped clear my mind and shake out the cobwebs… ;-) Sometimes the best ideas are the simplest, but you just have to know they exist in order to take advantage of them. Thanks! Here is how my clamping turned out this morning: -- HorizontalMike -- "Woodpeckers understand..." |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
