a great way to set....
Forum topic by toolie posted 03-10-2013 12:02 AM 1070 views 1 time favorited 6 replies Add to Favorites Watch
View toolie's profile
toolie
2134 posts in 2653 days
03-10-2013 12:02 AM
the height of TS blades and router bits (in a rouoter table) is in the 05/13 issue of wood magazine. it’s this month’s top shop tip and involves using a digital angle cube referenced off the the tool’s table. to set a blade or bit @ a height of 3/8”, for example, a 3/8” drill bit is placed on the tool surface and a flat piece of material bridges the shank of the drill bit and the blade or router bit and the digital angle cube is placed on the flat piece of material. as the blade or bit is raised or lowered, the digital angle cube approachs zero. at zero degrees, the blade or bit is at the same height as the shank of the drill bit.
since i’ve always had a bit of an issue with seting accurate cutting depths, i found this to be an extremely useful tip and just wanted to pass it along.
View kdc68's profile
kdc68
2658 posts in 2301 days
#1 posted 03-10-2013 02:31 AM
Thanks for sharing a great tip….An inexpensive solution opposed to purchasing those brass set up bars or those height gages, and various other gadgets….drill bits are cheap and come in a mutitude of sizes…
-- Measure "at least" twice and cut once
View DIYaholic's profile
DIYaholic
19623 posts in 2700 days
#2 posted 03-10-2013 02:41 AM
I saw that tip the other day and thought it was rather ingenious!!! Thanks for the reminder.
View DW833's profile
DW833
215 posts in 1907 days
#3 posted 04-19-2016 01:47 AM
Saw this post and was trying to find the article. Looked at the issues for SN in 2013, but couldn’t find it.
Does anyone know the issue number?
View hotbyte's profile
hotbyte
991 posts in 3000 days
#4 posted 04-19-2016 02:26 AM
Cool tip. Thanks!
View MadMark's profile
MadMark
979 posts in 1478 days
#5 posted 04-19-2016 04:45 AM
Buy the right dro:
Why jury rig it with the right tool about the cost of an angle cube? If you buy one, you can afford the other!
M
View shipwright's profile
shipwright
7992 posts in 2823 days
#6 posted 04-19-2016 02:35 PM
Maybe because you already have the cube???
