Makita MAC2000 2hp compressor - worth repairing??
Forum topic by DrewT posted 03-10-2013 12:02 AM 5250 views 0 times favorited 12 replies Add to Favorites Watch
View DrewT's profile
DrewT
33 posts in 1906 days
03-10-2013 12:02 AM
My father n law just gave this to me – motor doesn’t kick on and he thinks its a bad pressure switch. Curious if it is worth repairing?? Part appears to be no longer available…need some advice!!
12 replies so far
View DeckApe's profile
DeckApe
9 posts in 1952 days
#1 posted 03-10-2013 01:32 PM
I totally agree with Rick L, a temporary power cord to the motor would ‘prove’ if it is working. A quick search for ”air compressor pressure switch” on Google, Amazon, and E-bay should give you adequate choices for service & price. Good Luck!
-- You're want to do what with WHAT? Now that is a good idea!
View waho6o9's profile
waho6o9
8190 posts in 2574 days
#2 posted 03-10-2013 02:31 PM
http://www.ereplacementparts.com/makita-mac2000-2hp-air-compressor-parts-c-97_1547_9472.html
Here’s a schematic for you in case you need one. Looks like generic parts
are the way to go.
HTH
woodbutcherbynight
4541 posts in 2406 days
#3 posted 03-10-2013 02:32 PM
You do not need the manufactures specific pressure switch to repair this, as others posted these are readily available online or at a hardware store and let us not leave out those box stores with no knowledge employees’ telling you they don’t make them anymore. (laughing) That being said a word of caution is due when screwing with electricity, IT KILLS. I found one online and the instructions come in two languages, English and pictures so should be foolproof fix.
DrewT
#4 posted 03-12-2013 04:14 PM
I decided to take the compressor to a Makita Authorized Repair shop. I blew out the GFI plug in my garage when I tried to turn it on the last time. It’s best I don’t mess with anything electrical. Thanks for the suggestions – I have zero investment in this tool so if the repairs are 100- or less I’m good. Slowly trying to put together my shop – patience is not my best attribute!!
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2070 days
#5 posted 03-12-2013 06:32 PM
For those interested, the generic replacement for my makita of the entire power/pressure/on off switch box cost me $35 and has lasted 2+ years. Just had to screw down the three leads from the power cord, and connect it to the tank. Not to Fault you drew for letting the pros handle it, always a good idea when your are not comfortable or like me, too busy or lazy :), just adding information for others who might be attracted to this thread.
-- Who is John Galt?
DrewT
#6 posted 03-12-2013 08:40 PM
@joey – are you happy with your compressor?
joeyinsouthaustin
#7 posted 03-12-2013 10:08 PM
DrewT I now have four of them. 3 mac700 and a mac2400. Only the one mac700 needed a new controller, the others are still running strong and quiet..two of them are about 7 years old, and this is under heavy duty bordering on abusive conditions. Change the oil often and they are quite tuff…. but mostly nice and quiet.
DrewT
#8 posted 03-22-2013 12:08 AM
Compressor is back and working well – the start capacitor was bad. 54- invested ill take it!!
View philinMASS's profile
philinMASS
1 post in 337 days
#9 posted 06-21-2017 07:58 PM
OK. I have had the MAC AIR 2000 for several years. Sounds stupid, but I’ve never oiled it and I don’t see a place to oil? Any help would be appreciated, because today was the first time I have had an issue. It starts and then cuts out. It will trip the breaker if I don’t immediately shut it off. Where do I oil?
DrewT
#10 posted 06-21-2017 08:12 PM
Mine was old so the cord was bad, the pressure switch was replaced and if I recall the start capacitor. If you have a local Makita shop near you I would go there. I’m not technically skilled so I need help.
View Mainiac Matt 's profile
Mainiac Matt
8043 posts in 2326 days
#11 posted 06-21-2017 08:27 PM
these look like oiless compressors to me
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
MrUnix
6709 posts in 2196 days
#12 posted 06-21-2017 08:33 PM
OK. I have had the MAC AIR 2000 for several years. Sounds stupid, but I’ve never oiled it and I don’t see a place to oil? [...] Where do I oil?
- philinMASS
You don’t. Front page of the manual states it is an Oilless, Single-Stage, Direct-Drive Electric Air Compressor. If you are having issues, it is not from lack of oil. Could be as simple as a clogged air filter, stuck check valve, or trying to run on too long of an extension cord.
