Most Efficient Ways to Lap The Sole of a Handplane
« back to Hand Tools forum
Forum topic by Benvolio posted 03-09-2013 09:51 PM 2553 views 0 times favorited 13 replies Add to Favorites Watch
View Benvolio's profile
Benvolio
148 posts in 1894 days
03-09-2013 09:51 PM
... so at the moment I’m using normal 80g AlO paper with the occasional rinse under a tap to remove the swarf…
but it feels like it still takes forever to flatten my planes. I’m sure my paper blunts too quickly despite it being expensive friable Oakey paper.
I’ve been at it over two hours and I’ve still not flattened all the way across my Stanley 71 router plane.
And after three hours I never got to the dead bottom of my 1970s Record jack plane as well.
So although sole lapping will never be a quick job, I was wondering what you guys had found to be the most efficient way to flatten the soles of your planes…
Ben
-- Ben, England.
13 replies so far
View ShaneA's profile
ShaneA
6909 posts in 2561 days
#1 posted 03-09-2013 09:56 PM
I use the adhesive backed Mirka ( I think ) 80 grit, clean the dust debris often. When the paper looses it sharpness, it really drags out the process.
View Don W's profile
Don W
18684 posts in 2530 days
#2 posted 03-09-2013 09:59 PM
I get it close with a belt sander first. I have an old craftsman with a flat steel bed.
View sikrap's profile
sikrap
1121 posts in 3322 days
#3 posted 03-09-2013 10:03 PM
Is it a 78 (rabbet plane) or a 71 (router plane)?? If its either one of those, it shouldn’t take anywhere near 2 hours. What I do is glue a 60 grit sanding belt, a 120 grit belt and a 220 grit belt to a piece of melamine that’s about 15” wide and 4’ long. I stay on the 60 grit until I get a consistent scratch pattern or have removed the Sharpie marks on the sole, then spend about 30 seconds on the 120 and 30 seconds on the 220. I also use a ShopVac about every minute or so to remove the debris and keep the sand paper clean. For smaller planes like a 78 or 71, I’d just glue some 60 grit on one side of a piece of glass and 120 on the other.
-- Dave, Colonie, NY
View needshave's profile
needshave
175 posts in 1922 days
#4 posted 03-09-2013 10:09 PM
I do pretty much the same as shane. it just takes a while, I normally do it the last thing in the day, I leave when the arms get tired. Leave it for another day.
Benvolio
#5 posted 03-09-2013 10:13 PM
Hmm, it sort of sounds like I’m doing what you guys are doing.
as a rough ball park, how long would you guys take to prep the sole of a:
blockplane
smoother
jack
jointer
also, have you chaps had any experience of lapping compound? I’m not quite sure how it works – as I understand it it’s abrasive compound suspended in a lubricant that abrades the iron surface as it’s rubbed against the lapping surface. But will that not just wear out the granite tile? Also does lapping compound get blunted in the same way that abrasive paper does??
thanks
-- Ben, England.
View Deycart's profile
Deycart
444 posts in 2220 days
#6 posted 03-09-2013 10:17 PM
I might as well bring it up, Some planes do not need to be dead flat and the whole bed of the plane does not need to be co-planer. Check the article at http://www.handplane.com/66/thoughts-on-hand-plane-sole-flatness/
I will lap a smoother, but a jack is a waste of time. It is designed to take thick heavy shavings, not fluffy ones. There are many other things you can do to a plane to increase its performance that are more meaningful and take way less time. That’s just my 2 cents. As for lapping a joiner… I would rather buy a premium joiner so I don’t have to spend days doing it. My labor is worth more to me.
Deycart
#7 posted 03-09-2013 10:19 PM
I have tried lapping compound and the lapping plate from lee valley… Giant mess and you can get it just as flat with the above methods. A good quality sandpaper will take you much further.
Benvolio
#8 posted 03-09-2013 10:28 PM
Deycart – I agree with you about the jack (maybe even the jointer) but I’m inclined to use my low angle jack on the shooting board so I’m keen to get that flattened
-- Ben, England.
View Ripthorn's profile
Ripthorn
1454 posts in 2948 days
#9 posted 03-09-2013 11:05 PM
The other night I lapped a jointer, a jack, and a smoother. Took probably 3 hours for all of them. The jointer needed some work, as it had a little hollow right in front of the mouth. I did that on 100 grit, as I didn’t have anything lower.
View racerglen's profile
racerglen
3112 posts in 2743 days
#10 posted 03-09-2013 11:24 PM
Save some muscle, especialy if it’s a ways off (regardless of what type you’re doing, block, 71 or whatever) like Don W. said
belt sander, then move to the bench methods, whatever one you choose..same technique, scuff 1st to see where it’s off, sharpies marks, sand then when you’re near hit the bench.
I use a stationarly sander after very carefully blowing and vacuming any sawdust out, and same proceedure for going back to wood sanding. Work load VERY much reduced.
-- Glen, B.C. Canada
View paratrooper34's profile
paratrooper34
915 posts in 2915 days
#11 posted 03-10-2013 12:01 AM
I have lapped a jack plane, but only the one I use for my shooting board. I personally see no reason to lap anything above a smoother.
Benvolio, it sounds like something is amiss with your efforts. It should definitely not take that much work to get those two planes flat. You are probably correct in identifying the sandpaper as the problem. I do not use a belt sander, I use a large piece of plate glass with sandpaper adhered to it. I found that belt sander paper works the best for me. I just cut it and spray adhesive on the glass and paper. The belt sander paper seems to last quite awhile and the lower grits, 80 and 100 seem to be aggressive enough but don’t leave such a rough surface that it can be smoothed out pretty quickly once it gets a plane sole flat.
-- Mike
Benvolio
#12 posted 03-10-2013 12:26 AM
this is the paper I'm using , now I know it is good stuff because I’ve had great results on wood, so the question is why does it keep blunting??
the only thing I can think is that I’m using too small a sanding piece. Next time I’ll use the strip style of sandpaper that comes on a roll and hopefully be able to get longer strokes from it. maybe that’ll increase the efficiency of the cut?
I’ll let you know how that goes but until then I’m lovin the imput, guys.
-- Ben, England.
View jap's profile
jap
1251 posts in 2017 days
#13 posted 03-10-2013 12:53 AM
if you use belt sander paper and cut it and lay it flat you can use longer strokes which will speed things up.
-- Joel
