Severe Elbow Pain
« back to Coffee Lounge forum
Forum topic by Christopher posted 431 days ago 755 views 0 times favorited 18 replies Add to Favorites Watch
View Christopher's profile
Christopher
563 posts in 818 days
431 days ago
Anyone else get nearly crippling elbow pain in both elbows after doing any sanding?
Today after belt and orbital sanding for a short while (45 mins) both my elbows felt like they were going to come apart, the pain was nearly intolerable. It lasted for about an hour (spent pacing the room and sweating) and either self resolved or the ibuprofen kicked in. My elbows ache after I work but this was excruciating. I am still quite uncomfortable but I knew if I got on LJ’s I would instantly feel better!!
-- "That Government is Best that Governs The Least."-Jefferson
View Betsy's profile
Betsy
2386 posts in 794 days
431 days ago
Could be several things——your body posture as you use the tool. Your grip on the tool might be too tight. The constant vibration may jangle the nerves in the elbow to make them hurt.
I use special gloves that dampen the vibration and that helps some. The other is I try to use good body posture and I try to let the sander do the work and not hold onto the sander for dear life.
Hope that helps in some small way.
Christopher
431 days ago
Thankyou Betsy! I will try all of those suggestions! Kinda scared to sand now if I am going to be punished for it.
View roman's profile
roman
1125 posts in 791 days
431 days ago
You are not alone Christopher
my eyes never open in the morning….............they wince first, then they wince again, then maybe they peek open and then stay shut hoping she makes the coffee while I adjust my screaming back
by noon the painkiller pills kick in
Cheers
and repeat
View snowdog's profile
snowdog
808 posts in 880 days
430 days ago
I would guess it is your grip, try relaxing or at least telling yourself to relax every few mins. Let the tool work for you, stop and take a breath every few mins and notice how your body is feeling then try to relax your stance as you attack the tool again.
lazyfiremaninTN
528 posts in 851 days
430 days ago
Relax and go with the flow. Sounds like you are to tense while you are working. I would also try the vibration gloves.
View DanM's profile
DanM
88 posts in 607 days
430 days ago
I wouldn’t discount the possibility of tennis elbow. Technically known as lateral epicondylitis, you can get it from any number of activities which stress the tendons of the elbow in a particular way. I’ve had it in my right arm after using a roller to paint a small section (maybe 8’ x 25’) of the clapboard siding over 5 years ago. Just that one event, and while it flairs & subsides a bit, it’s never gone away. My wife has it in BOTH elbows from doing yoga, of all the damned things.
Needless to say, if the pain continues, you should have it checked out.
Dan
View waroland's profile
waroland
47 posts in 784 days
430 days ago
I use anti-vibration gloves and a light touch to keep my hands from hurting when I sand. I have not had my elbow hurt from sanding.
-- waroland, Mount Juliet, TN
View bruc101's profile
bruc101
133 posts in 440 days
430 days ago
I’ve had this problem, may not be your problem, for 20 years and being a professional woodworker it surely gets to be a chore to work some days. My doctors call my problem tendonitis or tennis elbow. Some days I will use the anti-vibration gloves and it does help. I also have this problem bad sometimes when I use a table saw all day, carving or turning on a lathe.
The doctors told me to wear a brace on my wrist at night because when i sleep my hands will drop down and more or less cut off the blood circulation. When I wear the braces the pain is usually gone the next morning.
Sometimes I will also wear the brace on my right hand when I’m working and that helps a little too.
I’ve learned over the years you not have to only take care of your machinery you have to take care of your body also. I wonder, where were those anti vibration gloves 30 years ago when I got started in woodworking after college.
I’m new to the forum and thanks to everyone who sent me welcome messages.
bruce
-- "Give The Gift of Life, Adopt A Child"
View DocK16's profile
DocK16
712 posts in 985 days
430 days ago
Chris
I believe Dan is on the right track diagnosing your problem as tendinitis, it is easily diagnosed but a little tougher to treat. You can test for it yourself, hold your arm out straight (elbow locked) and hand palm up have someone pull your hand down while you resist. If it reproduces the same pain it is a good indicator that it is tendinitis. It is not from vibration or circulation but from small tears in the tendon which attaches forearm muscles to the bony prominence at the elbow. Treatment is anti inflammatories, ice massage over the most inflamed point to reduce swelling and pain. I reccommend filling a styrofoam cup and putting it in the freezer and then tearing off the bottom when froze and use the insulated upper half of the cup to hold with the other hand and rub the sore spot. Avoid aggrivating activites as much as possible; gripping and twisting and especially using a hammer. Vibration dampening gloves can help. Therapy (ultrasound) and stretch techniques are helpful. Elbow manipulation can help break up scar tissue which can form in the tendon tissue. There are elbow braces to take the stress of the tendon while it heals which can take months. Hope this helps
-- DocK, WV
14932 posts in 749 days
430 days ago
I get it from the computer mouse. I must be spending too much time on LJ’s.
View Steelmum's profile
Steelmum
347 posts in 860 days
429 days ago
I worked in a factory and used to get tennis elbow. I wore a band around my forearm near my elbow and that helped. What I did to fix it was an exercise: stretch out your arm in front of you and raise and lower your hand at your wrist. ( like ‘paint the fence’ from Karate Kid). The idea is to strengthen the forearm muscle to take more of the work from your elbow. It is not much of a motion and it does take time. After a while I added a small weight, I started with a 1 lb. I did it every morning before work. Wore the armband at work, and it did get better. The armband was bought at the same place that you get the wrist brace and stuff.
Hope you feel better :)
this disclaimer is because I am not a doctor and I am not trying to diagnose or treat anything.
-- Berta in NC
View benchgirl's profile
benchgirl
1 post in 159 days
159 days ago
I have been hoping for a quick fix to this problem. My inside elbow feels like someone is injecting it with acid. Sometimes my hands ‘feel funny” and my shoulder gets into the act once in awhile especially when I am working through the pain.All my life I have been a doer and been repairing and renovating houses, now it hurts just to use a roller. I’m not getting relief. Its been going on for a year now, I ice it and it feels better but it does not last. I even laid off doing anything, not even picking up my little dog or grocies but in the end it returns like I didn’t even try to help myself. woe is me. My nasty doctor said I could have surgery as someone with carpel tunnel but said I wouldn’t want to do that… Pills, ice,braces and booze do not work. I would like to have a doctor open it up and let me have a look and maybe I could figure out the problem, it ain’t rock science afterall, oh yeah by the way I am a jeweler and this has seriously affected my life.
View Richforever's profile
Richforever
340 posts in 618 days
159 days ago
What I’ve come across: pain in the body is a lack of light energy flowing through the nerves. The light energy comes down through the pineal gland in the head and into the heart. It flows through the nerves into every cell in the body. By visualizing the light flowing through the body in this manner; and by relaxing the muscles; pain can go away. This is how Dad got rid of his cancer years ago.
-- Rich, Seattle, WA
17022 posts in 475 days
159 days ago
Hey Chris
A couple of things that have helped some of my students are sand at a height were you can comfortable have you arm extended most of they way, Let the sander do the work don’t apply hardly any down ward presser (Just steer the sander), have a soft pad under your work if possible such as the firm carpet pad ,carpet, or anything to help absorb the vibration, your sander could also also be contributory. Some sanders have much more vibration than others and soft start sanders can help to. I agree with the vibration absorbing gloves I just don’t think there safe for saw use. If all else fails talk your wife into sanding LOL
Hope this helps bud.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 483 days
159 days ago
45 minutes sanding is not a short time you need to take constant breaks. This is, and will be , a re-ocurring problem.In short your not used to it. So your muscles are complaining.build up to these things slowly.Alistair
Christopher
159 days ago
I appreciate the suggestions everyone, seriously.
View ellen35's profile
ellen35
541 posts in 330 days
159 days ago
I often recommend to my patients (I am a nurse practitioner) that they be pro-active. I recommend that, if there are no contraindications, they start out with 4 over the counter motrin tablets BEFORE they start whatever activity causes muscle pain. I do it myself when I do any heavy work and it seems to short circuit the inflammation responsible for the pain, ergo no pain. I am not recommending that anyone here try this – it is what I do and it works…you are on your own should you choose to try it too. Just an option!
Ellen
(did I get enough disclaimers to avoid a lawsuit!!!!)
-- Ellen on Cape Cod
View PirateOfCatan's profile
PirateOfCatan
53 posts in 297 days
159 days ago
First off, sorry to hear you are having any problems (and everyone else as well).
My recommendation would be to keep track of the motions, amount of time working and tasks which set off your elbow pain. Then once you have identified certain activities or motions you can start to find remedies for them. Others have already suggested lots of the “tricks.”
One of my physical therapist is all about the ice method to deal with inflammation, as others have suggested (direct ice for five minutes- no more). Another believes more in moist heat (heat pad, warm towel) to relax the area and “push” the inflammation out of the affected area instead of locking the muscles down with ice. Maybe if icing it doesn’t help, then heat would.
If you want to over the counter medicate your problem, then I would suggest plain ibuprofen. It can be found under many generic brands. Should you start to regularly take ibuprofen as an anti-inflammatory, then you could still take acetaminophen (tylenol) if you have a headache or different pain in addition to your elbow. Since they are different drugs they don’t count as double dosing. Just make sure whatever pain reliever(s) you use do not double up on the same drug (asprin, acetaminophen or ibuprofen).
Many people I know with joint pain swear by Tiger Balm.
If it should continue to be a problem, then go see your primary care provider to get a referral for a physical therapist (specifically an Occupational Therapist- OTR/L). They (OTR/L) deal with rehabilitation of injuries and injury management. The injury management is more what you would be looking for at this point. Identifying which nerves, tendons or muscles are being stressed would go a long way to finding relief.
*I am not a doctor, just someone who destroyed his shoulder/arm and went through three years of physical therapy in an attempt to clear up all the problems.
-- P.O.C.
