Making Dowel Rods
Forum topic by Guss posted 71 days ago 521 views 0 times favorited 14 replies Add to Favorites Watch
View Guss's profile
Guss
90 posts in 607 days
71 days ago
Hi I need to make some 5/8 dowel rods for a chair im repairing. I was wondering what kind of jigs you guys have or use to make your own dowel rods? Im looking for a fairly inexpensive way to make my own.
14 replies so far
View jim C's profile
jim C
1400 posts in 1265 days
#1 posted 71 days ago
huh?
Can’t you buy dowel rod in 3-6’ lengths?
-- Government does not solve problems; it subsidizes them.
View James101's profile
James101
227 posts in 82 days
#2 posted 71 days ago
Take closet rod from wives closet, then proceed with this method...
jim C
#3 posted 71 days ago
Oh Boy
Let’s make this stupid difficult.
Buy dowel rod at H.D. or go to Woodcraft and buy a bag of them.
jim C
#4 posted 71 days ago
H.D. has 5/8” x 48” dowel rod for $2.48 ea.
So whats the point of this thread?
Is Lumberjocks really getting this lame?
I’m pretty much done with logging in here. This is nuts.
View bondogaposis's profile
bondogaposis
1237 posts in 518 days
#5 posted 71 days ago
Sometimes you need to make dowels from exotic species that are not available to buy. Sometimes you just need a short piece and don’t have one on hand. There are lots of ways to make them and it is a good skill to know and a good way to use scraps. Here is one method, using a 5/16” roundover bit for a 5/8” dowel. First mill some 5/8” square stock then set up the 5/16” roundover bit in a router table. Roundover 4 edges. Don’t roundover the ends, the square ends will keep the dowel from rolling while you feed it into the router bit. Clean up w/ sandpaper and cut the square ends off and you have a 5/8” dowel made from the wood of your choice.
-- Bondo Gaposis
View paratrooper34's profile
paratrooper34
698 posts in 1118 days
#6 posted 71 days ago
Guss, you can make your own very simply. If you can get your hands on a piece of steel or iron, drill a 5/8” hole in it. Then you can take some pieces of wood you want to use for the dowels and get them close to 5/8” size. Taper one end and pound it through the hole with a hammer. Viola, there is your dowel. I did the same thing for dowels I needed on a project. Easy and inexpensive.
-- Mike
View sprucegum's profile
sprucegum
274 posts in 164 days
#7 posted 71 days ago
Someone had a really nifty jig on LJ a few days ago that used a band saw and electric drill. I am sure if you do a search you can find it. Anytime I have needed one in a species other than the standard birch ones you find at the lumber yard I have used my lathe. It is slow and requires the use of a steady rest if you need a very long one but it can be done. Most chair rounds are a little bigger in the center than on the ends so the lathe is about the only way if that is what you need.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View nwbusa's profile
nwbusa
867 posts in 452 days
#8 posted 71 days ago
Easy there, Jim. Fella is just asking a question here, no need to get pissy about it.
Guss, don’t know if this meets your needs or definition of inexpensive, but here is one option from LN. Lee Valley just came out with a dowel maker as well, but that one only goes up to 1/2”.
-- John, BC, Canada
jim C
#9 posted 71 days ago
nwbusa
The questions get lamer and lamer here.
Just my opinion.
James101
#10 posted 71 days ago
If it annoys you so much, just leave or don’t answer. No need to be a richard about it.
View gfadvm's profile
gfadvm
6611 posts in 856 days
#11 posted 71 days ago
I use Bondos method and just made 16’ of 1/2 AND 3/8” dowel in less time that it would have taken to drive to Lowes and back. A tip is to use some type of hold down/featherboard to hold the stock from wanting to climb up the bit. You can just clamp a section of 1x to the router fence above the bit.
jim c- Good luck finding Jatoba, mulberry, or elm dowels at LOwes!
View RiverWood's profile
RiverWood
107 posts in 926 days
#12 posted 71 days ago
Here is an idea from Woodgears. http://woodgears.ca/dowel/making.html#maker
-- My favorite projects were firewood bound
View Bill Swartzwelder's profile
Bill Swartzwelder
170 posts in 79 days
#13 posted 71 days ago
New guy here,
Thanks for posting the tips on making dowels guys. I joined this site to learn from some of you seasoned woodworkers, and old curmudgeons as well. :) All good advice, sometimes buying is better, and sometimes you need to do it yourself. Having the knowledge is always good. RiverWood, I really like the link you posted. Will come in handy for making traditional archery arrow shafts.
-- What if the Hokey Pokey really is what its all about?
View Guss's profile
Guss
#14 posted 70 days ago
I just want to thank you all for your input. I live in a area where you cant run to the store and get hardwood dowels let alone any kind of quality dowel And i don’t know the last time i have seen any straight dowels at home depot. you guys have given me some great ideas. thanks for not treating me like Jim!
