Bandsaw Blades
Forum topic by Anthony Finelli posted 03-08-2013 09:56 PM 1497 views 0 times favorited 16 replies Add to Favorites Watch
View Anthony Finelli's profile
Anthony Finelli
52 posts in 2714 days
03-08-2013 09:56 PM
I have a Ridgid bandsaw and the blade it came with sucks. I want to make bandsaw boxes, cut finger joints, cut curves,etc… what width should I be looking at and is it worth the cash to go with timberwolf blades? thanks guys, ~Anthony
-- Salem, New York "Find something you love to do and you will never have to work another day of your life"
16 replies so far
View SnowyRiver's profile
51457 posts in 3414 days
#1 posted 03-08-2013 10:07 PM
Not sure how wide the blade is that you currently have, but the thinner the blade the smaller the curves you can easily cut. I tend to use a 1/4 or 3/8 inch blade for general cutting, and a 1/2 inch blade for resawing. This blade also works good for sawing the lids on boxes. The wider the blade is of course the easier it is to cut a straight line. Another good blade is the Wood Slicer. This is what I have started to use for resawing and it’s a great blade.
-- Wayne - Plymouth MN
View blackcherry's profile
3337 posts in 3756 days
#2 posted 03-08-2013 11:22 PM
Timber Wolf and Wood Slicer from Highland tools are wonderful blades…costumer service from Timber Wolf is outstanding and willing to share value advise on types of blades for your cutting needs…good luck on your purchase…BC
View MonteCristo's profile
2099 posts in 2122 days
#3 posted 03-09-2013 04:13 AM
Manufacturers usually put a crap blade on a new machine. I would look into bimetal blades for a saw like yours. They are way more durable than regular blades and easily pay for themselves. On bigger saws I use carbide-tipped blades, but these don’t seem to be available in the narrow sizes you would need.
View mbs's profile
1652 posts in 2874 days
#4 posted 03-09-2013 04:36 AM
I like Diamond blades from I get the .032” thick 3/8” wide and use it for just about everything.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View cutworm's profile
1075 posts in 2727 days
#5 posted 03-09-2013 09:27 PM
We have the same saw. I use Carter blades. 1/2 and 3/8”. I like them.
-- Steve - "Never Give Up"
View Bill White's profile
Bill White
4878 posts in 3894 days
#6 posted 03-09-2013 10:52 PM
Wayne pretty well summed up the blade scenario.
View longgone's profile
5688 posts in 3242 days
#7 posted 03-09-2013 11:15 PM
I just added a riser block to my bandsaw a couple of weeks ago and needed 105” blades for it. The riser kit included a blade (whatever comes stock with the Powermatic). I odered two blades…one is a Carter and the other is a Woodslicer. I tried all of them while playing around with resawing some 9” wide maple, oak, cherry Padauk. The Woodslicer blade from Highland woodworks was far superior than the Carter blade and the blade that came with the riser kit was a joke…I have several Timberwolf blades that are 93’ that I used prior to the riser but I never used them to resaw anything thicker than 5”.
View Surfside's profile
3389 posts in 2107 days
#8 posted 03-11-2013 09:17 PM
We don’t need thick blades to resaw but choosing TPI is somehow a critical issue. Riser block option is always best for resawing. Enjoy cutting.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View sprucegum's profile
324 posts in 1931 days
#9 posted 03-11-2013 10:56 PM
I just bought a few blades from these guys they are lennox blades they seem to cut very well, the shipping is reasonable, and the price is ok. They make all of their blades to order so plan on at least a week. I was able to resaw some cherry with a 1/2” 3 tpi blade with the fence set at 90 degrees no run out at all.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View LeChuck's profile
424 posts in 2996 days
#10 posted 03-11-2013 11:29 PM
Can’t say enough good things about the Diamond blade mentioned above. Put on into my bandsaw and I don’t want any other now. And it doesn’t break the bank as the price is really low.
-- David - Tucson, AZ
View JaySybrandy's profile
78 posts in 1510 days
#11 posted 04-27-2014 09:06 AM
I use 1/4” Silverline bandsaw blades from ebay
View Picklehead's profile
1041 posts in 1863 days
#12 posted 04-27-2014 11:20 AM
Another vote for Sterling Diamond blades. Bimetal, sharp, not too $$$$
-- You've got to be smarter than the tree.
View deputy4989's profile
17 posts in 1459 days
#13 posted 04-27-2014 12:40 PM
I also use diamond blades, They work as good as timberwolf and are a lot cheaper
-- If we can't fix it, It ain't broke
View hairy's profile
2627 posts in 3466 days
#14 posted 04-27-2014 05:17 PM
View ScottKaye's profile
605 posts in 1886 days
#15 posted 04-27-2014 05:38 PM
I have found bimetal blades to be a great compromise they stay sharp and last much longer than a standard steel blade. I really like the Starrett brand of blades and they have good reviews. check them out on
-- "Nothing happens until you build it"
