Here's what I do to retain the "reclaimed wood" look.
Hit it with the orbital sander or finish sander with a high grit, like 220. Dont work up to the 220 using lower grits, just hit it with the 220 until you get it mostly smooth to the touch, while keeping the "character" of the saw marks, dings, etc.
But LIGHTLY, cause ROS's can take off a lot of material. Just run it over each spot for a few seconds.
Then hand sand 320 and go to 400, hitting all the nooks and crannies to eliminate any splintering. The surface will not be completely flat, there will be high and low spots, but thats part of the charm. And then just finish directly, i'm partial to Watco Danish Oil. Wet sanding with diluted danish oil using 400, and let set for 30 mins, then wipe off and repeat, and repeat, until the pores are filled, and then 600 or higher to achieve that glass like finish.
But if you want a more rustic finish, just sand to 320 and even to just 220, but hand sand after using the power sander. And dont wet sand, just let the oil soak in for about 30 mins, then wipe off. Or were you thinking of using a poly or lacquer?
