| Forum topic by lab7654 | posted 78 days ago | 646 views | 0 times favorited | 13 replies | ![]() |
78 days ago |
Topic tags/keywords: harbor freight miter saw garbage or not review I just looked at the new 12” miter saw from HF, and I have to say, it looks pretty nice. The belt drive is a huge plus for me. My old box store miter saw is on its way out, so I’ve been looking at some of the ones on the market. Have any of you put this through its paces yet? Here’s what I’m concerned about: At the very least, I’d like to have this saw to rough cut stock and then trim it with a crosscut sled and table saw. If this saw isn’t a winner I’ll either have to buy used or buy a straight up chop saw. I love the capacity of a sliding miter saw, and my cuts seem to be a lot more accurate on them versus the table saw or radial arm saw; it’s just what I’m used to. -- Tristin King -- When in doubt, sand it. |
13 replies so far
#1 posted 78 days ago |
is this the saw you’re considering? http://lumberjocks.com/EEngineer/blog/series/5532 -- there's a solution to every problem.......you just have to be willing to find it. |
#2 posted 78 days ago |
heard mixed things about it…with it being on sale I’ll be interested to see others weigh in. I have a compound miter saw right now – but not a slider. would love to have the extra capacity of the slider. -- - Steve Campbell |
#3 posted 78 days ago |
toolie, no, that is the older model. I’m not too interested in that one, it looks like the same exact saw that I have now, both are likely made in the same factory under the same tolerances. -- Tristin King -- When in doubt, sand it. |
#4 posted 78 days ago |
I have the 10” HF sliding compound mitre saw (chicago tools). It got good reviews, and I can make square cuts with it, or turn it either way to make vertical angled cuts. and I like the extra capacity of the sliding features BUT… -I had to take the fence off and bang it with a hammer to make it straight. -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
#5 posted 78 days ago |
I have had the 10” for a couple years. Had to return the first one due to varies defects, exchange was no problem and checked replacement before leaving the store. Had to remove the fence and file one slot to square it to the blade. The preset angles didn’t lock in that good and ended up filing the slots so the bar would lock in deeper(it was like the pointed rod was 1/4” dia. and the slots were 1/8”). -- Mike |
#6 posted 78 days ago |
Dust collection IMHO on any miter saw is a PITA. Maybe the Fe$tool but that is in a different price range. HF has a 90 day return policy so you can purchase it, put it through the tool test, review it for future readers, and then if necessary return it. Just keep the receipt and all packing materials. -- Jesse, Saint Louis, Missouri |
#7 posted 78 days ago |
It seems that they need a lot of tuning, but so does every MS if you really look at it. I have a small digital angle meter that I use on every cut 90 degrees or otherwise. It takes time to use it, but at least you know that you’re getting the right cut. I will say that my DeWalt MS does a real good job of holding a good square setting, but I still use the small digital meter. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#8 posted 78 days ago |
Jesse, I have my DeWalt in one of the FastCap hoods. It costs a pretty penny, but it’s so worth it if you have room. All the dust is flung into the hood where it stays unless you have a wind blowing it out. I just stuck a bucket under the spout at the bottom and forget about it. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#9 posted 77 days ago |
I picked one up this morning for under $100 by using a 20% off coupon. Pulled it out of the box and everything is pretty close to square and accurate so far. I haven’t taken too much time yet to fine tune it but so far it looks like it shouldn’t take too much work. I’ll check back and do a review when I’ve spent some more time with it. |
#10 posted 77 days ago |
I used to have one, I was very happy with it. -- Bert |
#11 posted 75 days ago |
Thanks for the replies everyone. To be honest, I don’t know how much I will use the miter saw once I get a good tablesaw crosscut setup. Right now I use it all the time and couldn’t be without it, but if I end up loving a crosscut sled then I may not even need a new saw. Anyway, looking forward to the reviews on the new saws. -- Tristin King -- When in doubt, sand it. |
#12 posted 75 days ago |
I would not trade my CMS for a truck load of sleds. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#13 posted 75 days ago |
Crank, honestly I’m thinking the same as you are, but I can’t really tell as I’ve never even used a sled. I don’t do a lot of wide crosscuts, so I might break down and get a fixed CMS. But there’s nothing I hate more than capacity limitations, hence why I bought a JET 10” jointer-planer when my money was probably better spent on a 6” floor standing jointer… Or perhaps I should quit rambling and just go and buy the dang saw and return it if it’s crap. -- Tristin King -- When in doubt, sand it. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3555 |
15813 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
