Source for 2" spring steel straps for steambending?
Forum topic by Loren posted 03-06-2013 08:15 PM 1831 views 0 times favorited 5 replies Add to Favorites Watch
View Loren's profile
9770 posts in 3522 days
03-06-2013 08:15 PM
I’m setting up to do some steambending. I’ve done it
before years ago and I made a compression fixture
out of low carbon weldable steel. It works well
but the strap I have is low carbon steel too and it’s
going to retain too much shape in bending I think.
I know I could buy the Veritas rig but it seems a
bit overpriced to me considering I already have
a compression fixture and just need a piece of
spring steel strapping.
5 replies so far
View JoeinGa's profile
JoeinGa
7732 posts in 1882 days
#1 posted 03-06-2013 08:30 PM
How ‘bout Northern Tool or maybe Harbor Freight? I’m thinking of the springs they sell for trailer axles…
View IrreverentJack's profile
IrreverentJack
727 posts in 2718 days
#2 posted 03-06-2013 08:45 PM
Loren, They make “2 banding/strapping. You should be able to get 10-20ft from someone that uses it. Try looking at construction sites that are getting loads of pipe or steel. -Jack
JoeinGa
#3 posted 03-06-2013 11:22 PM
Uhhmmm, WHOOPS! Open mouth, insert foot. :-(
I was thinking of a different kind of “spring steel”
Sorry ‘bout that. :-)
View higtron's profile
higtron
235 posts in 2552 days
#4 posted 03-06-2013 11:53 PM
Where I’m at Olympia Wa. we have a industial suppy co. were I have bought al different metals from they usually have whatever I need, I looked on line and you can buy the spring steel strapping you want but I could only find outlets that sold it by the roll. Look in your area for an industrial suppy house, also maybe give a HVAC co. a call they use strapping alot I hope this will send you in the right direction.
-- A friend will help you move, a good friend will help you move a body
runswithscissors
2604 posts in 1900 days
#5 posted 03-06-2013 11:59 PM
I use strapping steel in bending (with heat, no moisture), but I haven’t found any wider than about 1 1/2”. (Haven’t actually looked that hard). An old bandsaw blade might work, if you could find one that wide. You’d have to cut off the teeth or flatten them out on an anvil, I guess.
