| Forum topic by REO | posted 73 days ago | 337 views | 0 times favorited | 12 replies | ![]() |
73 days ago |
Topic tags/keywords: resource question diy remote dc switch auto dc switch I have seen several posts on those who want an automatic or remote start for their DC. There must be someone electronic savy that can come up with a diy circuit for sensing the load on a line and using that for a switch to turn on the dc. A post run timer should be a breeze as well. I have seen a GFI outlet conversion but it is not for someone who knows little about electrical components and it was manufacturer model specific. Come on you electron smart folks what are the options? |
12 replies so far
#1 posted 73 days ago |
For someone good with electronics and MCU that is programmed the right way could easily do just about everything. Of course, you would have to make sure you have the proper protections, and load (current) sensing inherently means you have to be in the circuit, so some design considerations have to be taken in to account there. For someone with the development board and an MCU, etc. it would be relatively inexpensive, but to buy the stuff to get up and started would not be super cheap. Remote start is really easy, especially if just a one button remote for on/off. Again, requires the use of an MCU and infrared transceiver set. -- Brian T. - Exact science is not an exact science |
#2 posted 73 days ago |
There’s also these… -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#3 posted 73 days ago |
I haven’t done this, but… I’d consider a current transformer (ie: a couple of turns of wire around one leg of your power circuit) through a resistor. Measure the voltage drop across that resistor (or pair of resistors), I’d use a microcontroller ‘cause I’m a software guy, switch a transistor which drives a 20A relay (or buy someone’s TTL to 20A relay board). Heck, thinking about this a little further… Current transformer using a couple of turns through a current limiting resistor. Use a zener diode and a small resistor to limit voltage across the rest of the circuit, and in parallel run the other leg through the feed which switches the relay. You could do all of the calculations yourself, or you could break out the parts box and a volt meter and just start playing. Be careful, you probably won’t generate a lot of current with that current transformer, but you could generate a lot of voltage. I’d start with like 2 or 3 turns around your feed leg, a 1k Ohm resistor, see what voltage you get with some known load (a 100 watt incandescent? 2 of ‘em?). Then scale up (or down) that resistor appropriately. If you can’t draw enough current to switch the relay, increase the number of turns and re-adjust any resistors. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#4 posted 73 days ago |
Dan Lyke – I think you are on the right track with the system you described, but I think I would use the signal voltage developed by the current transformer to bias a transistor that is in series with a relay coil. I think this would be more effective than trying to use the signal voltage off the current transformer. Paul -- Paul, Las Vegas |
#5 posted 73 days ago |
Yes, I think I mis-typed: You probably don’t want to drive the relay directly, you want a signal boost in there somewhere. Requires an external power supply, but easier for us software geeks to wire together. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#6 posted 73 days ago |
I’ve built similar circuits for RF sensing. I don’t think it would be a problem with a few diodes, resistors, and a small transistor that is capable of handling the curent to run the relay. -- Paul, Las Vegas |
#7 posted 72 days ago |
silid state relays are easy to find and cheap. what kind of simple down and dirty circuit does it take to turn one on. |
#8 posted 72 days ago |
I think I will just turn the shop vac on by the switch and be happy about it. (laughing) -- Live to tell the stories, they sound better that way. |
#9 posted 72 days ago |
A quick search reveals that other people have already figured out the current transformer thing: DigiKey has a whole bunch of current sensor options. As REO points out there are any number of solid state relays out there, although you probably want to switch a reasonable amount of current which may put you back into mechanical relay plus a resistor, transistor and diode (to keep the inductive kick from the relay coil from blowing out the transistor) territory. I’m a wuss, so I’d use a microcontroller like one of the Atmel AVR devices to measure the output of the current sensor on an A/D pin and make a decision on turning on or off the relay, but a little thinking should be able to come up with a solution that switches the whole thing through analog circuitry. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#10 posted 72 days ago |
I used a Christmas light remote control unit that I bought for a couple of dollars in an after Christmas clearance sale. It is the type that switches a unit that plugs into an outlet. I wired a single pole relay into the switched outlet, and used the relay to start the DC. Less than $20 for the remote and the relay. The remote came with 3 of the switchable outlets so I have 2 left over for another project. Works great from anywhere in my shop (24×32 ft). I attached it to a small clip so I can hang it on a belt loop and always have it handy. |
#11 posted 72 days ago |
I’ll second the Christmas light remote. I picked one up at Lowes in December for about $10. You have to watch because HD and Lowes both had them but one was rated 9amp and the other 14amp. Might as well go with the 14. |
#12 posted 72 days ago |
thats what i did ..lowes bought the remote for a ceiling fan $20….220 volt contactor with a 110 volt coil from the electrical supply house..$30..the remote operates the 110 volt coil that closes the 220 volt contact..easy pezy… -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
