| Forum topic by Amoc | posted 76 days ago | 447 views | 0 times favorited | 6 replies | ![]() |
76 days ago |
Topic tags/keywords: question I stopped by a local place a couple of weeks ago and picked up some pallets with the grand idea of reclaiming the wood for other projects. When I got into tearing the pallets down I found that the wood very seldom hung hung in there when it comes to pulling the nails (lots and lots). I wound up cutting out the unailed portions and chucking the rest. So here is my question for the masses~ What is the best method for tearing down a pallet? Would a vibrating saw blade be the best solution and then just kick the frames to the curb? -- Ken from Ft Hood, TX |
#1 posted 76 days ago |
Pallets vary greatly in construction. However, if I did it, I wouldn’t mess with pulling nails on pine ones. At least not the ends. Probably the ones in the center. If the pallet is better wood, oak, maple or such, then I would spend more time pulling nails also. Some people like having the nail holes also for show. Always good to recycle. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#2 posted 76 days ago |
The best way to do pillets is use your sawsaw with a metal cutting blade that is if your only useing the one by I use 9” general purpose nail-embedded wood&metal sawsaw blade’s by Diablo. |
#3 posted 76 days ago |
As David suggested. Then I pop the cut nails out using a cheap nail set or small pry bar. I use a rare earth magnet, epoxied to a 12” pc of 1/4” square dowel. Balance it on my finger and scan the wood, both sides. It will pick up any metal shavings and if I missed a hidden nail, it will stick to the wood. I tried a couple the wizard brand metal detectors and they missed more than they found. -- Mike |
#4 posted 76 days ago |
Get a good crowbar. Get a good nail puller. If you are of a mind there are those pallet breakers you can pick up too. I have built almost every project I have placed on here using pallets. Sometimes the nail holes look nice so I always painstakingly pull out all of the nails I can, and try not to cut anything. I am a bit of a wood hoarder. Another way to get them apart is to get a 1 foot piece of 4/4, lay it next to the section, and beat the 4/4 with a sledge against the section of pallet, and it pops the nails out; or bends them until you can place the crowbar underneath it. I found this method to be my go to. Also as much as you can when you are pulling out the nails, use the crowbar for leverage. When they construct pallets they use the most stubborn of nails. You can really find some great wood in pallets, and in most instances free wood if you don’t mind the work -- You can tell how good a woodworker is by the amount of clamps they have. I have maybe 6 (ones broken). Once I get more........ |
#5 posted 76 days ago |
I always try prying them out with a crow bar. To avoid splitting the thin pieces sometimes I’d just let the nail pull straight through the thin boards since there’s a nail hole there anyway. To pull the stuborn nails from the thick boards I’ll put a vice grip on the nail and just roll it back using the curved head portion of the grip to rock it out. -- Just a man with his chisel......... |
#6 posted 76 days ago |
Thanks guys for the help. I will look at Harbor Frieght and see about getting a cutting tool just for the nails. I will just get a couple of pallets at a time unitl I develop a system for removing the nail effectively. I will also try me5269’s method of a magnet and a stick to find nails. Again thanks to all! -- Ken from Ft Hood, TX |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3547 |
15775 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
