Circle cutting jig
Forum topic by Eagledad posted 03-05-2013 11:59 PM 1067 views 0 times favorited 2 replies Add to Favorites Watch
View Eagledad's profile
Eagledad
26 posts in 1915 days
03-05-2013 11:59 PM
Topic tags/keywords: question jig bandsaw
Has anyone had any luck using a circle cutting jig on a Ryobi 9” band saw? I know it’s not a great saw but it’s all I have right now? I seem to be having trouble with the motor not being strong enough and the wheel not cutting straight. Is it me or the saw?
2 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2005 days
#1 posted 03-06-2013 01:42 AM
It is a rather tiny and underpowered saw but unless you’re trying to cut fat dense wood at a super-fast pace it should be able to do a decent enough job – close enough that a cirlcle jig on the belt sander can clean it up.
If you’re trying to rough out turning blanks, it’s really not the saw for the job. But if you want to cut a 3/4”-1” circle for a plaque or something, it’s possible.
Blade tension will need to be very tight – no flex allowed.
And are you using a narrow enough blade? It usually says on the package how tight a radius you can cut with that particular width – that’s the maximum, battlling every inch of the way radius. Reality is usually a tad bigger.
If you make some relief cuts then once you make a quarter turn or so you’ll be able to remove some of the outer scrap. And if all else fails maybe you can make a simple circle-cutting jig for the router or router table.
Good luck
Joe
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Eagledad
#2 posted 03-07-2013 12:15 PM
Thanks! I tried the smaller blade and it did a pretty good job. I was able to get at least close enough to then use my disc sander to clean it up.
