Split Top Roubo vs. Standard Top
« back to Hand Tools forum
Forum topic by Drew - Rock-n H Woodshop posted 03-05-2013 05:47 PM 4505 views 0 times favorited 3 replies Add to Favorites Watch
View Drew - Rock-n H Woodshop's profile
644 posts in 2805 days
03-05-2013 05:47 PM
I have been toying around with the idea of making a WB and connot decide if I should make a standard or split top roubo. What are the advantages/disadvantages for a split top??? Any insights would be most helpful…..Drew
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
3 replies so far
View Rex B's profile
Rex B
320 posts in 2365 days
#1 posted 03-05-2013 06:07 PM
There are many who are much more knowledgeable than me on this subject, but I’ll get things started. The main advantage of building a split top is that you are building two small benchtops instead of one massive one. The two slabs will be much easier to move around during construction, and you can send them through a small planer.
A second advantage is the ability to clamp things in the middle of the benchtop by putting the clamp heads through the center crack.
Finally, many people end up building a “gap stop” that can be slipped into the crack to make the benchtop solid, but can be removed at any time.
-- Rex
View Kazooman's profile
Kazooman
1115 posts in 2066 days
#2 posted 03-05-2013 06:15 PM
Check out this thread.
http://lumberjocks.com/topics/47404
View blackcherry's profile
blackcherry
3338 posts in 3937 days
#3 posted 03-05-2013 06:18 PM
Split top have plenty of advantages as stated by Rex, I have the 21st Century style which is a split top with removable tray in the center which can be flip over to make a continuous bench top. I really like and can’t stress it enough is the clamping advantage of the split top…good luck on your decision and go for it no work shop should be without a beastly bench…Blkcherry
