Help with table saw problem
Forum topic by Praki posted 71 days ago 153 views 0 times favorited 2 replies Add to Favorites
View Praki's profile
Praki
86 posts in 533 days
71 days ago
Topic tags/keywords: tablesaw
My Delta contractor table saw does not start any more. It is less than two years old and used very lightly. Wired for 110V. It was working fine all morning and when I started it again, didn’t start.
The socket has power as verified by plugging a fan. I made sure that the motor cable which connects to a socket from the table saw switch is properly connected. I also checked the circuit breaker reset switch on the motor. I pressed it to reset to no avail.
What else should I look for? Anybody else had similar problems with Delta TS? I am dreading calling Delta support for help :(
Thanks
-- Praki, Aspiring Woodworker
Praki
70 days ago
Good news, I was able to trace the problem to the power switch. The motor is fine. I guess I will be spending some quality time with Delta support line.
View tooldad's profile
tooldad
192 posts in 251 days
70 days ago
Not saying your private investigation may not be correct. However most motors have an overheat breaker that trips until the motor cools down then reset automatically. some you have to manually reset by hitting the button. Just a thought.
Bookmark And Share This Page
