using water soluble Lockwood dyes
Forum topic by jerryo posted 106 days ago 351 views 0 times favorited 7 replies Add to Favorites Watch
View jerryo's profile
jerryo
123 posts in 1160 days
106 days ago
Topic tags/keywords: question oak finishing
I am making a white oak end table and was considering finishing it with lockwood dye. This would be my first
time using a water soluble dye and was wondering if anyone that has used them has any info they would like to share. Thanks, Jerry
7 replies so far
View RogerM's profile
RogerM
318 posts in 596 days
#1 posted 106 days ago
Jerry – I use a lot of water soluable analine dyes (mosty Moser’s). These take a little getting used to but after some practice you will probably prefer them over some of the spirit stains. These dyes are especially good on maple and pecan and are one of the main ingredients for bringing out the curl in curly maple. They are very user friendly, allowing you to vary the color simply by varying the amount of dye mixed with water. I try and use distilled water to avoid any reaction with minerals in the water. Also, once applied you can vary the color on the piece by applying more water (by rag or sponge) to reduce or lighten the color or put more dye on to darken the color. Before applying the dye a general rule of thumb is to stop sanding at around 150 grit sandpaper. Sanding much beyond this reduces the absorption rate in wood. Don’t lose faith on the first application. After the first coat dries, it will look dull and lifeless. Remember, you are just aiming for the color. After achieving the color you want, I use Seal Coat Shellac sealer dilluted with equal parts of alcohol. After rubbing this out you may apply Polyurethane of other finishes of your choosing. Please see http://lumberjocks.com/projects/63048 for a brief description on how I finish curly maple. Hope this helps with your project. Contact me if I can be of further assistance.
-- Roger M, Aiken, SC
View BinghamtonEd's profile
BinghamtonEd
652 posts in 567 days
#2 posted 106 days ago
Jerry,
I’ve used TransTint powder dyes, and I think Roger nailed it. The only thing he said that needs to be stressed is to get the color you want, and understand that your workpiece will look dull and lifeless after the dye is applied, and not to worry, it will look amazing once a topcoat is applied.
jerryo
#3 posted 106 days ago
Thanks guys. Roger, I remember your curly maple cabinets, they are truly a piece of art work. Would you recommend using grain filler on the oak or do you think sanding to 150 is enough?
RogerM
#4 posted 105 days ago
Jerry – The grain filler is a matter of preference. Oaks are open grain woods but White Oak is a little less so than Red Oak. Using a filler can be a bit of trouble and a bit messy but it yields a much smoother surface usually filling most of the pores that are associated with open grain woods. You may also consider using the filler on just the top surface of a table or desk so that it would be easier to write on. My thoughts are that you would use the filler to give a little more formal look to a piece. Although I have used paste wood fillers in the past, especially on walnut, I find that I am using it less and less on my projects. I have not had much experience with the new clear fillers but they sound like a good solution to the age old issues of filling pores. From an experience point of view, finish up a few pieces using the filler, not using the filler, using several concentrations, etc. One way to do this (if you don’t have a lot of extra stock) is to try these finishes on the back side of drawers, the underside of the top, or the back piece of of a drawer. I keep a lot of finish samples or varoius woods in a drawer noting the concentration measurements, etc. so I can come close in repeating some of the finishes that have worked well for me. Stay in touch. I would like to know how this works out for you.
View gfadvm's profile
gfadvm
6907 posts in 887 days
#5 posted 105 days ago
Many pore/grain fillers (like Timbermate) are water soluble so the water based dye will dissolve them!
View tenontim's profile
tenontim
2130 posts in 1942 days
#6 posted 105 days ago
I use water based dyes exclusively on white oak. No filler. I seal the dye with a couple of coats of 100% tung oil, then top with a wipe on varnish mix. Get it sealed good or the dye will spot if you spill anything on it.
-- Tim-- http://www.tmuli.com
jerryo
#7 posted 105 days ago
Thanks for the info gfavdm and tenontim, Roger I will keep in touch and let you know how it worked out, thanks for the info
