Bay window seat. Finishing?
Forum topic by Charlie posted 03-04-2013 11:11 PM 2117 views 0 times favorited 8 replies Add to Favorites Watch
View Charlie's profile
Charlie
1100 posts in 2256 days
03-04-2013 11:11 PM
Getting a new window installed in the living room. This one will be a bow window with about 17 inches of flat seating area. Mostly gonna end up being a lookout spot for the dogs. Hence an issue arises. The deck is going to be unfinished. I need to put a finish on it.
I need something that dries fast and isn’t too stinky as it’s living room and winter so ventilation is a concern. I’m not a HUGE fan of poly but I think this is an appropriate time and place to use it. Water based. Eventually the deck will get covered with some kind of cushion that my wife will make, but I won’t be able to keep the dogs off it and I’m thinking the poly is about as tough as I can get given the other criteria (fast dry and not stinky).
Does that sound right? Would you suggest something else?
AS it stands now I’ll probably be pickin’ dog hair out of the finish and I still haven’t figured out how to block off a 110 inch wide window just to keep the dogs off it while it’s drying, but…. I’ll have to come up with something.
8 replies so far
View GaryL's profile
GaryL
1099 posts in 2800 days
#1 posted 03-04-2013 11:23 PM
You’re on the right track with the waterborne poly. Since it’s a window seat maybe even go with an exterior product that has some UV absorbers.
Now for keeping the dogs at bay, or should I say out of, ......barbed wire ???....just kidding…....
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View Clint Searl's profile
Clint Searl
1533 posts in 2331 days
#2 posted 03-05-2013 12:12 AM
Varathane waterborne poly floor finish. Scrub the first coat back with maroon scotchbrite, followed by two full coats. Done in a day.
Charlie
#3 posted 03-05-2013 12:47 AM
Clint,
Can you explain the “scrub the first coat back” part?
And if I did this in a day (which I would hope to be able to do. Maybe even half a day if I can recoat in 2 hours) do you think it would be “dog ready” the next day? Or would it still be soft underneath for a couple days? The dogs are about 35 pounds and 45 pounds. So not huge but not purse dogs. (Beagle and Aussie Shepard mix).
I actually don’t care if it’s kept in pristine condition. This is a house. We LIVE here. We have dogs and they live here too. I just don’t want to damage stuff needlessly if I can avoid it. Because sooner or later I’m the one that has to fix it. :)
Clint Searl
#4 posted 03-05-2013 01:12 AM
Charlie, the first coat will raise the grain, and rubbing it down with the scotchbrite or 220 sandpaper will smooth things out so that following coats will leave a smooth finish. I’d try to keep the dogs off for 24 hours, but regardless, they’ll eventually scratch it up with their nails. Then it can be recoated with no problem.
P.S. You can always put knitted booties on ‘em. LOL
View MNgary's profile
MNgary
298 posts in 2387 days
#5 posted 03-05-2013 01:34 AM
If only there were some way to keep your beautiful finish protected until the seat cushions are made . . .
Maybe some old blankets?
P.S. perchance you want a finish that is easily repaired if the pets happen to scratch it. As for UV protection, the cushions null that need.
-- I dream of a world where a duck can cross the road and no one asks why.
Charlie
#6 posted 03-05-2013 02:53 AM
Actually, until the cushion gets made, I can cut a piece of carpeting to fit. And if I can keep ‘em off it long enough for it to dry I can make it 24 hours hehehe.
View bullhead1's profile
bullhead1
228 posts in 2219 days
#7 posted 03-05-2013 03:06 AM
String an electric fence across the opening. Seriously, I knew a guy that had a problem with his dog getting stuff off the counter (it was in his shop though) and strung an electric fence around it for a week. After that the dog never touched the counter again! OK, just an idea!
View leahwalkup's profile
leahwalkup
4 posts in 1667 days
#8 posted 10-03-2013 02:00 AM
Try to search more from it before you will decide what you are going to do and apply.
