Base unit, for a tray?
Forum topic by bandit571 posted 03-04-2013 04:54 PM 913 views 0 times favorited 4 replies Add to Favorites Watch
View bandit571's profile
bandit571
20264 posts in 2711 days
03-04-2013 04:54 PM
Topic tags/keywords: question oak cherry joining traditional rustic
I have two such trays. Both were designed to sit on an electric range when the stove is NOT in use. Only one gets used, now. The other needs a base to sit on, like for sitting up in bed. A look at the tray
The three side pieces are White Oak. The end ones have handles cut out into them. The rest of this tray is reclaimed Black Cherry. Reclaimed because it was at one time a floor joist!
Thinking maybe some short legs, maybe 12” or so. Maybe 1×1s even. The aprons would be almost hidden. Thinking maybe a half-lap joint to join two long rails in an “X” under the tray. Maybe a bridal joint where they meet the legs. I could make the bridal joint into a dovetail-like through joint. Going for hand tool looks. Looking at a way to attach the base to the tray.
As for the other tray
It can be the stove sitter from now on. Just old, reclaimed Pine, with some Beech as the rails. Daughter painted the star. One HEAVY tray.
bandit571
#1 posted 03-04-2013 10:44 PM
Got some work on the base done, just a start, actually.
Ripped two front legs, and planed the saw marks off
Along with two “back legs”. Set up to rip two apron/rails
By screwing a board down to the bench, that saw on the floor IS the rip saw. There is NO tablesaw in the shop. I then planned away saw marks, again
And started to work on a leg joint, or two
A variation of a “Bridal Joint”. Angles still need to be refined for a better fit. Two legs are skinny, the ones closest to the user. The thicker legs are further away. Rails are at an angle, too. Got the larger leg started
Still needs some fitting out, but one half of the leg assembly is getting about done
Somewhere in the middle of the rail, I’ll make an angled Half-lap joint. One more look at the Bridal Joint?
Be awhile, before this one is done….
bandit571
#2 posted 03-05-2013 08:50 PM
Second assembly is sitting in the clamps. I have the lap joint on the first assembly sawn out
Used a chisel to pare the joint smooth. Will saw the other half when the glue has had a chance to cure.
As for the saws used on this little project
Rather large ones, but at least they will saw Oak.
View DIYaholic's profile (online now)
DIYaholic
19623 posts in 2703 days
#3 posted 03-05-2013 11:58 PM
Who needs a table saw, jointer/planer or thickness planer???
I DO, That’s who!!!
You go git ‘em! Tray stand is lookin’ good!!!
bandit571
#4 posted 03-07-2013 05:42 PM
Tray and base are now together, thanks to five screws
While it may be a shame to hide all the joinery work under the tray, the joinery was the best option to attach legs to a tray.
May be a Cheap Butler”s Tray?
May stain the base a dark colour, so that the tray seems to float along???
