top coat for boiled linseed oil
Forum topic by ROB_IN_MN posted 03-04-2013 07:43 AM 4637 views 0 times favorited 5 replies Add to Favorites Watch
View ROB_IN_MN's profile
ROB_IN_MN
32 posts in 2048 days
03-04-2013 07:43 AM
Topic tags/keywords: question
I am trying to determine how long I should wait before topcoat a walnut/maple end table I made. I cut the BLO 1 part to 2 parts of mineral spirits and then wiped it off after a few minutes.
on the can, it says I can topcoat with poly. I’ve read on various forums that this is a bad idea. Should I topcoat with something?
Also, how long should I wait until I put a top coat on the end table?
5 replies so far
4868 posts in 2395 days
#1 posted 03-04-2013 12:45 PM
With the exception of shellac, the BLO should be cured before top coating…and that may take a day or two. After that most any oil based finish will adhere to it (including the polyurethane formulas). If it’s a water borne urethane, then wait 5-7 days. You can get around all of this if you put a barrier coat of dewaxed shellac (for Zinnser, this would be Seal-Coat). on the blo first. The shellac can be applied very soon after the blo sits, wit in a day or so.
View dhazelton's profile
dhazelton
2683 posts in 2198 days
#2 posted 03-04-2013 01:51 PM
You could do more coats of oil and finish with a good paste wax as well.
16272 posts in 4120 days
#3 posted 03-04-2013 02:58 PM
There is absolutely no problem putting oil based poly over BLO. ( I doubt there is a problem with water-based poly either, but I won’t comment because I haven’t cone it). As far as waiting time, I would let the BLO dry for a couple of days just to be on the safe side. If it feels dry to the touch you should be fine.
If this were a strictly decorative piece, I would recommend you just finish with wax. But since BLO and wax doesn’t give you very much protection for something like an end table, I think the poly top coat is a good idea.
ROB_IN_MN
#4 posted 03-04-2013 03:04 PM
I ended up waiting a couple hours until after it already was dry to the touch, so I figured…what the heck. Seems to have worked fine.
thanks for the advice.
View John's profile
John
190 posts in 3485 days
#5 posted 03-04-2013 03:59 PM
I use PolyAcrylic over BLO all the time. I wait a few days to a week. I like to wait a week just to be sure.
-- John, Long Island, NY
