How do I Sharpen Router Plane Iron?
Forum topic by Hawgnutz posted 71 days ago 296 views 0 times favorited 7 replies Add to Favorites
View Hawgnutz's profile
Hawgnutz
505 posts in 613 days
71 days ago
Topic tags/keywords: router plane sharpening
I recently got a full-sized router plane (Stanley #71) and ordered the pint-sized version from Lee Valley. The problem I face is sharpening them. With the short reach and the mounting bar at 90 degrees from the cutting edge, I cannot use my regular honing guide, so I am left to the vagaries and unpredictability of free-hand sharpening. Anyone have any insight on how to fabriacate a jig to do this?
Thanks,
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
71 days ago
I freehand my router plane iron. It’s so small that it’s really not that difficult.
-- - Real men read directions
View Jarrod Zion Murphree's profile
230 posts in 260 days
71 days ago
Second that; freehanding is the best way. In my opinion it is not worth the extra effort to sharpen a micro-bevel on a router plane blade unless you plan to use it primarilly for hogging out dadoes, etc… I use mine to do cleanout only (usually less than 1/32” of material, just enough to make the dado even all the way across), so it stays sharp for a really long time.
First, I would hone & polish the bottom of the blade, and then flip it and hone/polish the bevel. Put your stone on the edge of your bench and secure it so it doesn’t get knocked off. Then you can just do what some call “sideways” sharpening; running the blade perpendicular to the stone. A 1/4” blade with a 25 or 30 deg bevel gives plenty of surface area to be able to keep it steady. May take a little practice if you aren’t used to freehanding.
Regards, JM
-- Jarrod, Eagle Nest, NM http://anthologyfinefurniture.wordpress.com
Douglas Bordner
2732 posts in 600 days
71 days ago
I freehand too. Good to see you again Hawg…
View John in SD's profile
John in SD
34 posts in 349 days
66 days ago
Hey….I enjoyed your answers for hawg ....now ,on this same topic…..does anyone know where to purchase irons for a #71 ?
-- I'm not slowing down,everythings just going by faster!
Hawgnutz
66 days ago
View Bill Hall's profile
Bill Hall
98 posts in 403 days
66 days ago
You can also use the irons from the Lee Valley router plane. I just got a 1/4” for my #71. Free shipping last week really helped.
http://www.leevalley.com/wood/page.aspx?c=2&cat=1,41182&p=52609
-- Log...log...it's big, it's heavy, it's wood!
View Derek Cohen's profile
Derek Cohen
26 posts in 505 days
66 days ago
I would recommend that you first create a shallow hollow grind using a DRemel or sandpaper around a dowel…
This will make it a relatively easy task to hone a microbevel on the face of the bevel. I do not recommend trying to hone full flat face – you will just round it.
Regards from Perth
Derek
-- Building and Reviewing Tools at http://www.inthewoodshop.com
Bookmark And Share This Page
