R4512 - Riving knife very loose
Forum topic by lumberjoe posted 03-04-2013 01:10 AM 1294 views 0 times favorited 6 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2899 posts in 2424 days
03-04-2013 01:10 AM
I noticed lately I have been having a really hard time clamping down my riving knife after blade changes. I took the back off the saw today to clean things out and noticed the riving knife armature is REALLY loose – I probably have a solid 3/4” play from left to right.
Two questions -
1 – If anyone with an R4512 can take a look at theirs and see if there is a nut on the bottom of the armature that attaches the lower arm to the cast iron, that would be appreciated. It appears to be a threaded rod, but I’m not sure if there should be a nut there
2 – Any other ideas?
View pwalter's profile
pwalter
79 posts in 2760 days
#1 posted 03-04-2013 04:21 AM
Hey Joe. I also have a r4512 and have a heck of a time getting the riving knife clamped in. If i remember, i will take a look at mine tomorrow.
View Sodabowski's profile
Sodabowski
2375 posts in 3009 days
#2 posted 03-04-2013 11:14 AM
2 – do you think you can shim the thing to get the play out?
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View me5269's profile
me5269
43 posts in 2343 days
#3 posted 03-04-2013 01:19 PM
Hi Joe,
Here’s a link to the parts diagram and list. Mine is hard to push down (and lift up), I use the end of a hammer to push it down. There is some adjustment play in it when the lever is up.
Mike
-- Mike
lumberjoe
#4 posted 03-04-2013 01:31 PM
Thanks mike. I did find the parts diagram and it looks like everything is there. The side-to-side play does not change when the riving knife is locked down on my saw
me5269
#5 posted 03-04-2013 01:34 PM
By any chance is the clamp assy (item #43) loose? Not sure if you check the spring and spring seat (item #41 & 42). maybe spring is broken/missing? just guessing
-- Mike
lumberjoe
#6 posted 03-04-2013 05:55 PM
I fixed the issue with the wiggly armature. There are 3 set screws behind the blade arbor. I tighten them down (PITA as only half the hole is exposed) and that took all of the wiggle out. The lock down is still absurdly difficult. I disassembled the whole thing, cleaned it (it actually wasn’t that dirty because I am anal about keeping the saw clean) and it made no difference at all.
