| Forum topic by Woodsurgin | posted 78 days ago | 347 views | 0 times favorited | 5 replies | ![]() |
78 days ago |
I purchased a sliding table for my Delta shaper. I wonder why the shaper fence isn’t set up to reference the the shaper table to keep it square with the groove, like the fence does on a cabinet saw? |
5 replies so far
#1 posted 78 days ago |
A parallel-to-the-miter-gauge-slot fence is unnecessary to a spindle cutter, Woodsurgin. The only important relationship between the cutter and the fence is the exposure of the cutter. I am puzzled by what the application of a sliding table to a shaper will add. I have never seen one in a professional shop. All those folks that I have known in those settings were interested in productivity, safety and repeatability. If the latest iteration of a sliding table for a shaper has descended from a professional product, I am ready to learn about it and those two attributes. If it is just appearing on the Rockler level, I’m skeptical of its value. I remain open to learn here, and I appreciate your bringing up the subject. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#2 posted 78 days ago |
Lee, the main application I can see is cutting tenons on |
#3 posted 78 days ago |
Ah, makes perfect sense, Loren. I was hoping we’d hear from you on this. Thanks! Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#4 posted 76 days ago |
Yes, I can cut tenons. I bought a floor model Delta 3 hp shaper from Johnson’s workbench. It formerly had a Delta sliding table mounted on it. I was able to buy a Delta sliding table from CPO Delta. I have been experimenting with making tenons and like the fact the sliding table holds the boards securely. I am also wondering if the Delta 1/4 hp power feeder will be powerful enough for running long boards for flooring. |
#5 posted 76 days ago |
If you want to use the slot in either the shaper or the router table, squaring up the fence is a must. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15768 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
