| Forum topic by whitebeast88 | posted 84 days ago | 395 views | 0 times favorited | 11 replies | ![]() |
84 days ago |
Topic tags/keywords: tablesaw blade question since upgrading to a new ridgid ts last week i’m working on upgrading my blades.i’ve added a diablo 24 tooth rip blade,i put a diablo 40 tooth general purpose on my miter saw.now i need a recommendation on a good blade to cut plywood with i’m trying to minimize tear out.also i’d like a 7 1/4 blade for my circular saw,cause i break it down with my cs to make it more manageable.i’m looking for a reasonable priced blade,i tried looking on the reviews page and didn’t find much,so any recommendations would be appreciated. thanks marty. -- It don't have to be straight,it's just a suggestion!!! |
11 replies so far
#1 posted 84 days ago |
Not to sure about a plywood blade, but if yer trying to minimize tear out you need to make a zero clearance insert for your saw. Pretty simple to make and they make a heck of a difference. -- Mark |
#2 posted 84 days ago |
Try looking at they http://www.sommerfeldtools.com the finest around. Blades, cabinet bits, routers and very dependable -- Grandpaj |
#3 posted 84 days ago |
IMO only but you might be better off with a higher tooth crosscut blade in your miter saw than a 40 tooth. The 40 tooth can crosscut and rip both but you would get smoother and less tear out with a crosscut blade in your miter saw. -- Measure "at least" twice and cut once |
#4 posted 84 days ago |
The 40T Diablo has a pretty steep hook for a miter saw if it’s the D1040X. That blade is better off on your TS. A good 80T Hi-ATB blade will be best for clean cutting in ply, and would be great on your CMS as well….keep on it the CMS for crosscuts, put it on the TS for plywood. I’d stick with Infinity, Forrest, Ridge Carbide, Freud, Tenryu, CMT, Amana, Irwin Marples, DeWalt Precision Trim or Guhdo. I’d avoid Avanti/Avanti Pro, DW construction series, Oldham contractor series, Irwin Marathon, HF, Skil, Vermont American, Ryobi, Workforce, and other off names that are poorly made. Tips for picking saw blades -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#5 posted 84 days ago |
Agreed with Knotscott on avoiding Avanti/Avanti Pro. I bought a 60 tooth in a special, buy one get one free. There aren’t very good at all. In fact they are horrible, IMO. I see now why they offering that special….live and learn -- Measure "at least" twice and cut once |
#6 posted 84 days ago |
I’ve been using Freud thin kerf on the TS and I love it. It cuts everything and the kickback risk is much less powerful when and if it happens. I’ve been using this blade for about 6 months and have noticed no dulling. It cuts today as well as it did 6 months ago. They cost around 90$. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 84 days ago |
With the saw you have, I would definitely stay with the thin kerf blades. The Freud blades are readily available at big box stores and will give you good service. -- Friends don't let friends use right tilt contractor saws...... |
#8 posted 84 days ago |
Knotscott is right on with his recommendations in my opinion. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#9 posted 84 days ago |
I put away my Forrest, Ridge, and custom Cermet 10” blades after 30 years for a Freud Fusion 8” a couple years ago. It’ll do 98.7% of what the 10”s will do, less expensively and friendlier. -- Clint Searl.............We deserve what we tolerate |
#10 posted 83 days ago |
Just my opinion…............ but that’s not the brightest suggestion I’ve ever seen -- Friends don't let friends use right tilt contractor saws...... |
#11 posted 83 days ago |
thanks everyone on the recommendations.been at the hospital with my mother part of the day and just now getting to check my post. i had read awhile back that a 40 tooth general purpose blade was good for a cms.glad i’m told different now.i’ll definetly check out the recommended blades. knotscott-i’m going to read your post tonight,thanks for sharing. -- It don't have to be straight,it's just a suggestion!!! |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15815 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
