Question: not having worked with a tail vice bench before, how much play should there be when using it. I have a bench where you can "jiggle" the block up and down with a play of about 1/2". Just seems like a lot of slop compared to the front vice. Words of wisdom? Thanks.
Astralan, there should not be play in a tail vise like that. Well, I should say there should not be in mine. I do not know if you have a similar one, but here is something I can relate that might help you: When I moved, the movers took the tail vise off my bench. After I put it back together, the tail vise had way too much play in it (up and down, like you explained). After some inspecting on the vise, I found there was a bolt that they loosened that I did not catch when I put it back together.
Check out the vise and make sure everything is tight and in position where it should be.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
