Making Table legs from 4/4 Lumber question
« back to Joinery forum
Forum topic by bbasiaga posted 03-02-2013 04:51 AM 6068 views 0 times favorited 14 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1231 posts in 1989 days
03-02-2013 04:51 AM
Topic tags/keywords: question oak planer jointer veneering joining
I’m going to make some legs that are 2.5” thick (and also 2.5” wide). I’ve got some 15/16” red oak for the project. There were no thicker boards in stock.
Since this is my first time laminating, I’m debating how to best handle this. The boards I have are pretty flat, but I’m figuring I’ll need to joint and then plane them enough to get them to glue together. I’ll cut them wide and long, and end up with somethng around 4” longer than desired, an inch or so wider than desired, and shy of 3/8” too thick. The extra length can help me if any snipe occurs during facing operations, and the width if something slips during the glue-up. And I’ll need to plane the final assembly back to the proper thickness.
Does this sound like the right/best way to do it? I was also thinking I could maybe get away without the planing/jointing ahead of time if the boards are flat enough, then just joint/plane out any imperfections in the final assembly. Somehow, that seemed more risky though. What do you all think?
I’m pretty new at this, so any advice would be much appreciated.
-Brian
14 replies so far
Smitty_Cabinetshop
15342 posts in 2612 days
#1 posted 03-02-2013 04:58 AM
Brian, been there and done that early in my hand-tool experience. Specifically thought I didn’t have to keep going when I was planing some recycled oak that was in turn going to be glued up to make legs for a small table.
The dark like on the right leg is the result of my ‘good enough’ approach.
I’d suggest your plan to plane smooth, for best fit, is preferred over the ‘flat enough’ plan. :-) Then you’ll get laminated legs that have more wood character than workmanship character.
This table is made from the same recycled material, just cleaned up (jointed and smoothed w/ planes) better.
bbasiaga
#2 posted 03-02-2013 05:08 AM
Thanks for the advice. Can you elaborate on what caused the dark color?
-Brian
View toddbeaulieu's profile (online now)
toddbeaulieu
814 posts in 2998 days
#3 posted 03-11-2013 04:06 PM
I made some 4” legs for an assembly table a few weeks back from red oak. I milled them first and glued them up. I then milled the glued up piece. You can barely see the seams. I always go a little long to deal with planer snipe. I don’t usually get any meaningful snipe on the jointer, now that I’ve learned not to press down as the tail passes over the cutters.
View Marcus's profile
Marcus
1163 posts in 2014 days
#4 posted 03-11-2013 04:58 PM
What the others have said…joint, plane, glue up and then joint/plane again to get a nice square leg.
View AandCstyle's profile
AandCstyle
3050 posts in 2251 days
#5 posted 03-12-2013 02:32 AM
Another thought if you choose to laminate the boards to the desired thickness and do get some visible glue lines, you can apply a thin board (veneer) to those faces. When you round over the edges, that one glue line will disappear. This would be easiest if you have a band saw, but you can also cut veneers with a table saw although that wastes more wood. HTH
-- Art
Smitty_Cabinetshop
#6 posted 03-12-2013 03:55 AM
Brian – the lines were evidence of an outer layer of darker, aged wood with a bit of finish as well. I said ‘good enough’ when it wasn’t.
View sprucegum's profile
sprucegum
324 posts in 1992 days
#7 posted 03-12-2013 10:32 AM
I have laminated quite a few table legs with varying results bottom line is the more time you take fitting and matching color and grain the better the results will be. If the material is not overly expensive I often glue up a extra leg while I am at just in case I don’t like the look of one you can always use the spare leg for turning stock or some other project.. Clamp the crap out of them and leave them as thick as possible that way if you end up with some voids in the glue joint you can saw through the center of the joint with your table saw and reglue.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Monte Pittman's profile
Monte Pittman
29217 posts in 2332 days
#8 posted 03-12-2013 11:31 AM
Plane everything, assume nothing. Never trust store bought lumber to be square or evenly thick.
bbasiaga
#9 posted 03-12-2013 01:01 PM
Thanks guys. I did go ahead and joint and plane each piece before gluing. I’ll try and get some pictures up this weekend. They came out pretty good. I tried to paint the glue on as evenly as possible and I clamped them pretty hard. They cleaned up on the table saw pretty well when done, and I haven’t found any major gaps in the glue lines.
Its a good tip to veneer the side with the joint lines on it….I will keep that idea in my back pocket for sure!
-Brian
View Fettler's profile
Fettler
200 posts in 1991 days
#10 posted 04-02-2013 11:05 PM
The trick IMO is getting the best grain to show on all 4 sides of the legs. You could try making the legs in 4 pieces with 45 degree bevels on the edges, but this could causes problems in glue up. IIRC, green and green would just butt joint and then vaneering the two sides with the seams.
-- --Rob, Seattle, WA
View Marty5965's profile
Marty5965
158 posts in 1939 days
#11 posted 04-03-2013 03:03 PM
+1 Fettler, but that only works if your lumber is quartersawn (AFAIK).
-- Marty, Columbus, OH, learning every day....
View HorizontalMike's profile
HorizontalMike
7754 posts in 2908 days
#12 posted 04-03-2013 03:15 PM
Looking at Smitty’s example and thinking out loud… Where are you planning to put the center of the bottom of your taper? I see Smitty kept one 4/4 whole, and tapered the rest of the laminate.
HorizontalMike
#13 posted 04-03-2013 03:17 PM
double deleted
View dlucy67's profile
dlucy67
2 posts in 1925 days
#14 posted 11-06-2014 01:54 PM
Is there anything special you’d need to do when gluing up a couple of pieces to make a table leg regarding grain direction? Does that matter when you’ll be gluing full-length faces of the leg parts to each other?
