It's been covered before but no definitive answer yet- Plywood or MDF workbench top ?
Forum topic by Sirgreggins posted 03-02-2013 01:03 AM 1993 views 0 times favorited 28 replies Add to Favorites Watch
View Sirgreggins's profile
Sirgreggins
299 posts in 2230 days
03-02-2013 01:03 AM
I’m looking into making a wall mounted folding workbench and i’m not sure what to use for it. MDF which is nice and flat but doesnt hold a screw well or plywood which can hold a screw, but might not be that flat. Either way i’m buying a 4’x8’ sheet and cutting it into 4 layers which i’ll laminate together for a nice thick top 48”x 24” The bench will have solid wood edging and a masonite skin. what do you think? i would like to use some bench dogs with a vise and i’ll be doing mostly routing work, assembly work, some hand planing, and maybe some dovetails (which is why i’m doing 4 layers).
28 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3643 days
#1 posted 03-02-2013 01:08 AM
If this was a finishing/assembly table – I would say MDF – cheap , flat , and replaceable.
If this is a construction/work table that will see banging (mallet), and need to hold material against hand planing forces (shear forces) and the likes -then I say plywood which can hold screws and be mounted more securely to the wall without it coming off during work.
View Manitario's profile (online now)
Manitario
2630 posts in 2878 days
#2 posted 03-02-2013 01:14 AM
no definitive answer because there isn’t one…If you are using 4 layers and covering with masonite, I’d use whatever is cheapest.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3473 days
#3 posted 03-02-2013 01:52 AM
3 layers of ply, one MDF then the masonite top
Use contact cement for the masonite top
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
Sirgreggins
#4 posted 03-02-2013 05:35 PM
Rocky, i think maybe i will do what you suggested just using one extra layer of ply. I probably wont glue the masonite down just so can replace it once it gets nasty. for the plywood, should i go with shop grade or homecenter hardwood veneer stuff?
RockyTopScott
#5 posted 03-02-2013 05:53 PM
I would go to Home Depot and get the good Columbia Forest ply. You are only going to use half a sheet so you would have the other half for something else nice.
Goof idea not to glue the Masonite. When I do something similar I just put on an edge like 3/4 ” poplar to keep the top from sliding around….maybe a few 23 gauge pins.
Sirgreggins
#6 posted 03-02-2013 06:04 PM
thanks for the feedback Rocky. i really appreciate it!
Sirgreggins
#7 posted 03-02-2013 10:22 PM
ive read in a number of places that gluing solid edging to plywood or mdf will cause it to warp and crack b/c it can’e expand others say it’s not a problem. Thoughts?
RockyTopScott
#8 posted 03-02-2013 10:25 PM
Good, not goof. Sorry
View bondogaposis's profile (online now)
bondogaposis
4723 posts in 2346 days
#9 posted 03-02-2013 10:45 PM
4 layers of MDF is going to be extremely heavy for a folding workbench.
-- Bondo Gaposis
View Kazooman's profile (online now)
Kazooman
1006 posts in 1947 days
#10 posted 03-02-2013 10:52 PM
I had the same thought. If this is to be 3/4 MDF then the bench will weigh about 80 pounds!
Sirgreggins
#11 posted 03-02-2013 10:57 PM
in my garage we have storage rack bolted to the concrete floor and studs. I know 4 layers of ply and 1 of mdf is heavy but not too heavy i dont think. if you think about it 4 layers of ply is no heavier really than the 4’x 8; sheet, its just thicker b/c it’s laminated. believe me this would be firmly bolted in place :-) If a wall can hold lumber rack than this bench shouldnt be too much to handle. There will be folding legs to support it. The design is based off this: http://lumberjocks.com/projects/67529
Smitty_Cabinetshop
15345 posts in 2613 days
#12 posted 03-02-2013 11:26 PM
A wall that can’t handle an 80 lb folding bench isn’t a wall worth having…
View Tennessee's profile
Tennessee
2872 posts in 2509 days
#13 posted 03-02-2013 11:36 PM
+1 for Rocky. Like the masonite top.
View Bobmedic's profile
Bobmedic
379 posts in 2797 days
#14 posted 03-03-2013 01:25 AM
Torsion Box?
View Dakkar's profile
Dakkar
323 posts in 1922 days
#15 posted 03-03-2013 01:41 AM
That’s exactly the approach Norm Abram took with the first bench plan he built on New Yankee Workshop. He simply screwed a sheet of 1/8 masonite over plywood so he could replace the masonite when it got messed up.
showing 1 through 15 of 28 replies
