craftsman 113.228360 cheapo wood lathe
« back to Woodturning forum
Forum topic by toolie posted 03-01-2013 08:46 PM 5751 views 0 times favorited 11 replies Add to Favorites Watch
View toolie's profile
toolie
2105 posts in 2531 days
03-01-2013 08:46 PM
i’ve a question about the captioned lathe, that i got for $20. i’ll preface this by saying i’m a WW, but not a turner. i’ve no real interest in turning at this point, but for $20, i rounded out my tool arsenal with a lathe (of sorts), which was the only type of WW tool i didn’t have. my question involves the tailstock.
here is a link for the lathe’s OM:
http://vintagemachinery.org/pubs/222/5739.pdf
specifically, is the center spur (part l) supposed to rotate within the spindle tail stock (part f)? or is the work piece supposed to rotate on the center point (part z) that sits within the center spur (part l) that is held by the spindle tail stock (part f)? should anyone know of a video addressing this tail stock question, a link would be appreciated.
11 replies so far
View Harryn's profile
Harryn
62 posts in 2490 days
#1 posted 03-01-2013 09:38 PM
A cup spur looks like a small circle with a point in the middle, and does not rotate in the talilstock. the wood spins on it. It usually has to be tightened during work as it wears away the wood. Another type is a live center ball bearing type that rotates with the workpiece. This is the best type and does not cause any burning around the cup.
View Wildwood's profile
Wildwood
2239 posts in 2037 days
#2 posted 03-01-2013 10:05 PM
Looks like both your spur center & cup center come with removable points. While spur center goes in headstock and does rotate, cup center in tailstock should not. While want a point in your spur center, there are times want to remove point in cup center.
Because cup centers squeal or burn wood while turning and require lube not used that much today. Today most lathes come with a live center for tailstock that does rotate because have bearing (s). Some come single or multi point.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=lathes-acc-cent-revtail
-- Bill
View bandit571's profile
bandit571
19155 posts in 2586 days
#3 posted 03-01-2013 10:18 PM
Actually, I have used that same type of lathe, since I bought one NEW, back in the 90s. Even bought the four piece chisel set for it. Still have it in the shop, too.
toolie
#4 posted 03-02-2013 02:53 PM
bandit571. does your unit have a live or dead tailstock?
bandit571
#5 posted 03-02-2013 04:27 PM
It came with two dead tailstocks. The plastic fan thingy has long since broken away, have to run the lathe without the cover. Watch the joint in the bed. Mine cracked where the two pieces of “T” rail joined. Had to weld it back together on one side. Can still bolt it together. Using a small flat-bladed screwdriver as a tensioning rod.
It is sitting there under all the shavings. Been a good little lathe for me. Still use it to make a few handles
toolie
#6 posted 03-02-2013 05:54 PM
does this look like a live center that would work with my cheapo lathe?
http://www.ebay.com/itm/MT1-LIVE-CENTER-MORSE-TAPER-TRIPLE-BEARING-1-MT-0002-/330774854618?pt=BI_Tool_Work_Holding&hash=item4d03b7bbda
bandit571
#7 posted 03-02-2013 08:58 PM
You can also buy them at Penn State Industries little site…
toolie
#8 posted 03-03-2013 01:23 AM
decided to go with this one from woodcraft:
http://www.woodcraft.com/product/2021120/24449/woodriver-60-degrees-ball-bearing-live-tailstock-center-1-morse-taper.aspx
we’ll se what happens when it gets here.
View MaroonGoon's profile
MaroonGoon
281 posts in 1861 days
#9 posted 04-09-2013 07:34 PM
Toolie, I’ve got the same Craftsman lathe and am looking to buy a pen mandrel for it so I can turn some pens. I looked at the tailstock center that you got and noticed it has a #1 morse taper. Is the headstock a #1 morse taper also? I wasn’t sure which the lathe used since it doesn’t mention it at all in the manual (or from what I could find).
Or would anyone possibly be able to post a good pen mandrel that would fit with this lathe? This might deserve its own thread :P
-- "Only put off until tomorrow what you are willing to die having left undone." -- Pablo Picasso
View Rick_M's profile
Rick_M
11085 posts in 2282 days
#10 posted 04-09-2013 08:32 PM
The manual Toolie linked to only mentions 1MT accessories so like other vintage Craftsman lathes, the headstock is probably a #1.
-- http://thewoodknack.blogspot.com/
MaroonGoon
#11 posted 04-09-2013 09:44 PM
Great thanks, Rick. I think I’m going to purchase this one then.
http://www.pennstateind.com/store/PKM-ELC.html
It seems to be the only pen mandrel they have with a #1 morse taper :-/
