| Forum topic by noone | posted 82 days ago | 395 views | 0 times favorited | 10 replies | ![]() |
82 days ago |
I was going to try this as I need to nail up some 2” x 3/4” trim after a cabinet is installed. I was hoping to just be able to glue it and then pin nail it and be done with it, without having to worry about fixing holes. I have 1” pin nails to use to fasten 3/4” material while the glue dries. Is this normal practice? |
10 replies so far
#1 posted 82 days ago |
It’s a great idea! If the wood you are using has a deeper grain (like oak), try keeping the pins in the grain. This helps hide them. -- Friends don't let friends use right tilt contractor saws...... |
#2 posted 82 days ago |
It will be painted poplar trim, painted white. |
#3 posted 82 days ago |
As small as those pins are, the primer may well cover the holes without using any filler or spackling. -- Friends don't let friends use right tilt contractor saws...... |
#4 posted 82 days ago |
Sounds good to me as well. 8-) -- HorizontalMike -- "Woodpeckers understand..." |
#5 posted 82 days ago |
I would say no…I use 18ga brads on anything solely to hold stuff in place and align but would never trust that for a permanent installation. I always follow with a 16ga on thinner trim work, 15ga where it will work. |
#6 posted 82 days ago |
If you are gluing, I still think the pin nailer will do, IMO. -- HorizontalMike -- "Woodpeckers understand..." |
#7 posted 81 days ago |
Glue is a much stronger fastener than brads. The pins, or brads, are simply holding the trim in place until the glue dries. There is no reason to use larger nails if the trim is being glued. -- Friends don't let friends use right tilt contractor saws...... |
#8 posted 81 days ago |
Pins and glue will work just fine. I do it often. -- bill@magraphics.us |
#9 posted 81 days ago |
I use a combination of nailers from 14 gauge up the the headless micro nailers and also in combination with adhesives from standard glues to heavy duty panelling adhesives and all of this pending what kind of trim is being used…….
-- "Good artists borrow, great artists steal”…..Picasso |
#10 posted 81 days ago |
I use glue, then a pin nailer, then for white painted items I wipe a little caulk in the hole with my finger tip. -- Dale Manning, Carthage, NY |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
