How to bend wood without a steamer?
Forum topic by shifthappy6 posted 110 days ago 2182 views 0 times favorited 70 replies Add to Favorites Watch
View shifthappy6's profile
shifthappy6
20 posts in 111 days
110 days ago
Hi,
Im new here but am a 32yr journeyman carpenter and woowoker. I am working on an old buffet, turning it into a kitchen island. My problem is the base around the bottom was less than stellar and needed to be replaced, the issue is that on the center front there is a simi round portion! (If pics will help i can try and post some) and I’m having trouble trying to bend thie 3/4×6 inch base that I bought to replace it. It is about a 32 inch radius and I need about a quarter of that radius. I do not have accesess to a steamer nor do I have the disire to try and make one that i’ll never use again. this base is fairley detailed so i dont think I can make relief cuts in the back deep enough to do any good. So if anybody has suggestions I’m open, please feel free.
Thanks
Jim
BTW, if it makes any difference the wood i am trying to bend is Alder I think ;(
70 replies so far
View sprucegum's profile
sprucegum
293 posts in 195 days
#1 posted 110 days ago
Not a clue how to bend without steam or relief cuts but I have rigged up a steamer in the past using a metal 5 gallon bucket and the gas burner from my turkey fryer. All you really need is boiling water and a way to pipe the steam into a wooden steam box. I used a bucket that had a cover, I simply cut a hole in the cover the size I wanted and placed the steam box on top. It was a long box so I made the steam come into the center and supported the ends with sawhorses. Some folks use stove pipe or old furnace duct for the steam box. Sorry I have no pictures it was a one shot deal to bend some shafts for a one hoss sleigh. Like you steam bending was not something I wanted to do a lot of but the time and money to rig up a steamer this way is minimal.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View kdc68's profile
kdc68
966 posts in 474 days
#2 posted 110 days ago
Without knowing exactly what it is your trying to do, I suggest you look into this option…..Thin strip lamination. Build a form to the shape you want out of MDF. Make your thin strips extra long and wider than finished size. Apply glue to all layers and stack together like the layers of plywood. Apply to the form and start in the center and work out to the ends. You will need lots of clamps. The pieces will slip and slide some, but they are oversized so no worries there. Let cure for at least 24 hours before removing clamps. Cut to finished size afer the 24 hour dry time
-- Measure "at least" twice and cut once
View pwalter's profile
pwalter
62 posts in 782 days
#3 posted 110 days ago
I know you said you don’t have any desire to make a steam box. But a lot are just made out of PVC pipe with the ends capped off. It would literally take you 10 minutes. Any I am sure somewhere down the line you could reuse the PVC pipe. Just a suggestion.
View Francisco Luna's profile
Francisco Luna
936 posts in 1591 days
#4 posted 110 days ago
make a plywood or MDF form with a tighter radio, because after gluing up several layers of 1/8” of an inch, they are going to spring off about 25%.
I hope that helps.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View JesseTutt's profile
JesseTutt
712 posts in 308 days
#5 posted 110 days ago
I have no experience with steam bending outside of taking a couple of classes. Both classes recommended air dried wood as easier to bend.
View renners's profile
renners
1952 posts in 1167 days
#6 posted 110 days ago
Make a form and and do a bent lamination, as kdc suggests. Probably the easiest thing to do.
-- Never trust a man in winklepickers
View Jim Finn's profile
Jim Finn
1089 posts in 1120 days
#7 posted 110 days ago
I have made a form and did bent laminations using 3/16” thick straight grained oak. I soak the oak strips for 24 hours or more in water and run hot tap water over them to warm them up just before applying yellow glue and lots of clamping together to the frame. Remove from the frame after dry, this takes about 3 days…. in my experience.
-- In God We Trust
View Loren's profile
5034 posts in 1845 days
#8 posted 110 days ago
I think maybe he is trying to bend a fancy moulding.
shifthappy6
#9 posted 110 days ago
Thanks for all the quick responses, unfortunately I can not laminate do to the piece I’m use already has a detailed face. I have however built a form to wrap it around, tried soaking for several days! Did nothing at all to soften it up so it looks like I will be steaming after all. I do have a turkey fryer so I hope this works, I just have to make a new lid for it as I don’t want to cut a hole in this one :) how long should something like this steam? And then how long do I have to work with it before it starts getting hard again?
shifthappy6
#10 posted 110 days ago
Thank you Loren, that is exactly what I am trying to do!
89156 posts in 1775 days
#11 posted 110 days ago
Some woods do not bend well. soaking in hot water and or steaming should work in a couple hours max depending on the thickness of the piece your working on. I think a photo would help. It might be something you just have to make a new piece for.
#12 posted 110 days ago
How big a bend, again?
You said 32” radius, which is a doable bend. Then
you said 1/4 of that, which is an 8” radius – which is a
pronounced bend you will not succeed with.
You can make a shallow steam bend just using muscle
to get it on a curved form.
#13 posted 110 days ago
View DS's profile
DS
1848 posts in 618 days
#14 posted 110 days ago
IT will take heat to get this thing bent…
The form is a good idea. I would also consider a metal strap clamped along the outside face to prevent expansion along the outside face. (flashing will work—clamped on the ends)
If you wet the piece and heat it with a heat gun as you add clamps to your form you should have good results.
View Cosmicsniper's profile
Cosmicsniper
2155 posts in 1356 days
#15 posted 110 days ago
I would saw kerfs into the back of the moulding and bend it. If the kerfs show at the top of the moulding, I’d bend a small piece of trim (or trim segments) to cap it. By using segments of the trim, you should be able to soak them, heat them to about 400 degrees in an oven, and then bend them in place over the work. Tape them down until dry, then glue down.
Look at the bindings in a guitar to see the principle of a kerfed binding.
-- jay, www.allaboutastro.com
showing 1 through 15 of 70 replies
